Civic 2002 sway bar links
Old Jan 27, 2015
And3's Avatar
And3 is an unknown quantity at this point
Hello guys, i m new here and i need some help/advise from you.
With the wheels on the ground i noticed that both (front) have a gap. (easy with the hand i can turn them) is that ok? or should be fixed? are not bent or broken.
Thanks.
Old Jan 27, 2015
Re: Civic 2002 sway bar links
I'm not clear on this yet.
Pics?
Old Jan 27, 2015
And3's Avatar
Pics?
I m talking about this
Old Jan 27, 2015
I kinda meant the gap part you mentioned. That's what I couldn't picture in my head.
What I see in your pic looks normal to me.
Yes they are supposed to be able to pivot a bit, both ends of each link are comprised of a ball-and-socket type joint with a threaded stud sticking out.
Old Jan 27, 2015
And3's Avatar
like i said, are not bent or broken. only that gap worried me, very easy to move it when the wheels are on the ground.
Old Feb 1, 2015
this is a broken piece (mine). yours is just as they should be.
Old Feb 1, 2015
ex2peria10's Avatar
ex2peria10 is an unknown quantity at this point
i thought they should be solid and with no movement (because of the 4 rivets on the side). But from what i understand needs to be replaced only if are broken?
Old Feb 1, 2015
They can become noisy as wear develops between the ball stud and nylon liner. You would be able to feel it as a small amount of free play when you grab the ends of the sway bar and push/pull up and down.
The 4 dots you see are what secures the nylon liner into the cup area.
Old Feb 1, 2015
they should move or your suspension will not move.
CarStuff
Dec 6, 2020 12:52 PM
bsmiley
Apr 27, 2015 01:27 PM
zcwagon
Apr 24, 2015 05:18 PM
smmahan
Apr 15, 2015 08:17 PM
CapYoda
Nov 11, 2001 05:17 PM
