HELP! My 2nd, 4th, 6th and reverse gears don't engage but my 1st, 3rd, and 5th work
Someone please help. I have an 06 Honda Civic Si and all my lower gears( 2nd, 4th, 6th and reverse) no longer stay in gear. It will engage then pop back out but my upper gears(1st, 3rd, and 5th) all engage and stay in gear. I replaced the clutch and it still isn't back to normal. Now I am smelling this awful smell after driving for more than 10-15 min. My coworker said he smelled fluid when I cranked her up. Hope someone can help b/c I miss my car being normal.
Re: HELP! My 2nd, 4th, 6th and reverse gears don't engage but my 1st, 3rd, and 5th wo
What's the smell caused by? Figure that out and it might solve your problem.
Is the trans fluid low? Had it been run low? That could cause internal damage.
Is something obstructing the shift linkage on the trans? Is a cable loose on the trans?
Have someone work the shifter while someone else watches the linkages on the trans.
Thanks for replying. It smells like exhaust. And I'm not sure if the trans fluid is low but I can check. When I state that it doesn't work, I mean that I can shift into 2nd gear but it won't stay in gear. It pops back to Neutral. My upper gears engage and work perfectly.
How many miles on this rig?
Is the fluid low?
Has the fluid been replaced regularly?
Every 30k?
Ever?
If it's not caused by linkage or fluid issues then it's probably internal in the trans, which means overhaul time.
Is the fluid low?
Every 30k?
Ever?
It has been changed but not often as suppose to. It was changed when I replaced my clutch last year. I didn't know how often I was suppose to change it.
Very true. I've been told that before but my piggy bank may not be able to afford that. I will definitely look into pricing the repair. Is there a particular trans fluid you recommend?
[/QUOTE]
That's what my manual said so that's what I put in there. Wasn't sure if there were different ones for that type. #blondemoment
I don't know much abt my car but I'm trying to learn as much as I can b/c I Iove Ivy(my car's name) to death!!!!
Nothing to do with engine swaps, will move your thread when I get into a computer that can move it...
Nothing to do with engine swaps, will move your thread when I get into a computer that can move it...[/QUOTE]
Moved.
You really should try to figure out what's really wrong with it before you just get mad and dump it because you assumed the worst.
ORskier
May 3, 2015 12:54 PM
tylerginevan
Apr 27, 2015 12:29 PM
Linda0818
Apr 23, 2015 11:30 AM
CilverCivic
Nov 11, 2001 02:18 PM
Russps
Nov 8, 2001 02:00 AM
