99 civic LX high idle issues, tried everything please help
Old Nov 29, 2014
gradles21's Avatar
gradles21 is an unknown quantity at this point
Ok guys I've never posted in a forum before so forgive me if I sound like a noob. I've searched every forum I could find about this issue and I still haven't been able to fix this issue. I drive a 99 LX D16y7. So my idle issues started a few months ago at a stop light, I had the car for a year up to this point with absolutely no issues. So I was at a light and all the sudden the rpm started surging from 800 to 2000 until I turned off the engine and restarted it. It would do this only a few times a week but never gave me a CEL. I read that this issue was most likely a iacv so I ordered a new one and installed it, the surging stopped but would idle high, usually around 1200 rpm. At almost every stop now the CEL will show up and give me a P0505 code and immediately start running like s*** until I could reset the code and then it would run fine but still idle at around 1200, or I can hold the rpm at about 1500 and the CEL won't come on but that's getting annoying. I also did a idle relearn procedure after I installed the iacv. I figured I just got a bad iacv so I was able to return it and I ordered another but ended up having the same issues. So with all of the forums I've searched and youtube videos I've watched including ericthecarguy this is what I've tried: bled coolant system, replaced iacv twice, cleaned TB, replaced plugs and wires, checked for and fixed the vacuum leaks that I found with carb cleaner, bled coolant system again, turned idle speed screw all the way down. After all of this I'm now stuck, please help someone I'm sick of having the pull over on the side of the road to reset the CEL
Old Nov 30, 2014
Brandon@fattysmotorsports's Avatar
Former Sponsor
Brandon@fattysmotorsports is an unknown quantity at this point
Re: 99 civic LX high idle issues, tried everything please help
Tried replacing throttle position sensor?
Old Nov 30, 2014
gradles21's Avatar
I unplugged the tps with the engine running and the idle immediately changed and the CEL came on so I'm assuming the tps works
Old Dec 1, 2014
Former Sponsor
Well then the tps works fine. I hope you don't have to get a new ECU.
beneditti
Jan 15, 2016 12:31 PM
Pr0n1s
Apr 30, 2015 03:08 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
vtechcivic
Apr 21, 2015 06:58 PM
streetglower123
Apr 12, 2015 10:56 AM
