Feeding wires thru firewall
Old Oct 14, 2014
sandman66's Avatar
sandman66 is an unknown quantity at this point
I have mounted some auxillery lights on my 2002 civic but can 't find anywhere to feed the wiring from the engine compartment to the interior. Can anyone help with this?
Old Oct 14, 2014
GolNat's Avatar
Prelude Owner
Re: Feeding wires thru firewall
You can punch through the firewall where the main harness goes through. I believe its on the passenger side.
Use a coat hanger to help fish the wires through after you cut/slit a hole in the rubber grommet.
Old Oct 15, 2014
sandman66's Avatar
I don't think its as easy as that. I removed a couple panels and glovebox but there is no easy access.
Old Oct 15, 2014
Kennykid2002's Avatar
Kenny the Ricer
The main harness grommet is in the passenger foot well, behind the carpet and slightly up.
You'll have to remove the big plastic panel that blocks access.
Another way is to drill through the driver side firewall.
Old Oct 15, 2014
GolNat's Avatar
Prelude Owner
It's easy to get too. Just need to remove the one panel and pull back the carpet like Kenny said.
Random pic from Google. You can see the grommet, you just need to make a slit and push a coat hanger through. Then attach your wires with tape and pull through.
Old Nov 12, 2014
Ripulez's Avatar
Ripulez is an unknown quantity at this point
I think its worth noting that while you can easily go though the main harness grommet, with a little work you can create your own hole through the firewall, provided you seal the hole and use a grommet or an equivalent.
SimpleUser
Apr 24, 2021 02:54 AM
Kevinsisco
Aug 31, 2015 12:04 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
