so upset
Old Oct 2, 2014
petept's Avatar
petept is an unknown quantity at this point
so upset
Hi guys and gals. I picked up a very nice 2001 civic 5 speed a couple weeks ago and I crawled under to change oil and filter and was very happy to see a very nice dry under side, no rust, beutifull. I put I. 5w20 maxlife. Weeks go buy I go under today and oil pan is wet, and above it also. Valve cover looks dry, front and back. What the heck happened. I called original owner to ask what oil he used and he said green bottle quaker state 5w20 every time he said religiously. What do you think. Could be going on. Car drives, runs great, hop I didn't get screwed.
Old Oct 2, 2014
GolNat's Avatar
Prelude Owner
Re: so upset
Sounds like under the car was cleaned before the sale. Probably needs an oil pan gasket, it's an older car.
Make sure your oil filter is tight, not to tight.
Old Oct 2, 2014
Re: so upset
and above it also.
Oil collects and runs all over when you pull the oil filter off. Some filters/blocks will let oil dribble all the way over to the trans area so it appears like a rear main leak.
Check for leaks from
Oil pressure switch (near the oil filter)
VTEC valve, (if equipped, the rubber seals harden and leak BAD when they get old)
Distributor O ring, (or internal shaft seal if the inside of the dist is full of oil)
Oil drips from the timing cover areas
Old Oct 3, 2014
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Re: so upset
OP, if you're upset about an oil leak, wait til your head gasket blows. Then you'll really have something to be upset about.
Good luck with the oil leak.
Old Oct 3, 2014
mikey1's Avatar
Re: so upset
it could just be oil running down from when you removed the old oil filter,
is your oil filter done up tight enough? maybe its leaking?
Hqly2001
22
Jul 12, 2015 06:44 PM
civicns
May 8, 2015 09:49 PM
SPIDEY
Mar 12, 2003 04:38 PM
