so upset
so upset
Hi guys and gals. I picked up a very nice 2001 civic 5 speed a couple weeks ago and I crawled under to change oil and filter and was very happy to see a very nice dry under side, no rust, beutifull. I put I. 5w20 maxlife. Weeks go buy I go under today and oil pan is wet, and above it also. Valve cover looks dry, front and back. What the heck happened. I called original owner to ask what oil he used and he said green bottle quaker state 5w20 every time he said religiously. What do you think. Could be going on. Car drives, runs great, hop I didn't get screwed.
Re: so upset
and above it also.
Check for leaks from
Oil pressure switch (near the oil filter)
VTEC valve, (if equipped, the rubber seals harden and leak BAD when they get old)
Distributor O ring, (or internal shaft seal if the inside of the dist is full of oil)
Oil drips from the timing cover areas
civicns
May 8, 2015 09:49 PM
