Popping noise after spring instalation???
What springs? Sportlines? Check to see if the plastic sleve is still on the spring, if it is move it upwards by twisting it with the car jacked up, if thats not the problem take it back to the shop and make them fix it for you.
Hey I had the same problem when I installed my neuspeed sports. It turned out it was the rubber ring that is at the top of the strut. It was popping in and out of place. You better get it looked at quick because I drove like that for only a day and it had started to crack. I reseated them and its worked fine since.<cross fingers> Good Luck!!
Jonas
Jonas
reqy
Jun 1, 2015 07:05 AM
Youshoe
May 22, 2015 09:36 PM
