CEL On
Old Sep 2, 2014
Kneedragvillian's Avatar
Kneedragvillian is an unknown quantity at this point
CEL On
My CEL light came on the other day in my 96 Ex so I had it checked out and it puled the code p0453 Which is EVAP System Pressure Sensor/Switch Circuit High... Need some help on what to replace.
Old Sep 2, 2014
Re: CEL On
High voltage was detected in the fuel tank pressure sensor circuit.
My first guess would be a wiring problem. Got mice? Rodents chewing wires seems to be a huge problem in my locale.
I would have already had a scanner on it that can read and display live sensor data to see what value that sensor is reading.
FTP: 3 wire sensor: There should be a ground, a 5v, and a signal return.
Atmospheric pressure should give a reading of about 2.5v.
Note there are 3 different harness junctions these circuits pass through, so that makes about 15 different connections to possibly cause trouble LOL.
I'll suggest a wire diagram and voltmeter if you have to trace wiring.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Luluharp
Sep 27, 2015 11:56 AM
Mannimarco
Sep 7, 2015 10:01 PM
dantheman42
Sep 4, 2015 01:10 PM
jpat21
Sep 3, 2015 11:32 PM
