New guy from AL
Old Aug 27, 2014
bluciv's Avatar
bluciv is an unknown quantity at this point
New guy from AL
Hey all. I picked u an 2001 Civic coupe DX for a deal. I drove the wheels off my old 86 Accord so I'm hoping this will be as reliable. But I know I need to fix previous owners f'ups. Thankfully only 2 other owners. 1.7 auto. Since I've bought it I always thought it was dark blue and it is actually black.
Old Aug 27, 2014
Re: New guy from AL
Welcome!
Old Aug 28, 2014
GolNat's Avatar
Prelude Owner
Re: New guy from AL
Welcome!
Old Aug 28, 2014
bluciv's Avatar
Re: New guy from AL
Thanks guys. Now I need to get on code info and start searching. I need to do a clean on the IACV. 195k and it looked like the original plugs. I bought a set of NGK double platinums but I still have a miss on number 3. Swapped coils with another cylinder and the miss stayed at number 3.
Old Aug 28, 2014
Re: New guy from AL
Is it a dead hole? Does it have spark on that hole?
Compression test.
Old Aug 29, 2014
bluciv's Avatar
Re: New guy from AL
I'll do more testing tonight or tomorrow. I know at the plug for the coil I'm getting 12v with the key on. I didn't do a spark test. I'm going to fire it up for a minute and then pull the plug and see if it is wet and test for spark.
btw: your location sounds familiar. Have a good day Kent.
Old Aug 30, 2014
bluciv's Avatar
Re: New guy from AL
Update. I did a spark test on an old plug. Good spark. So I pulled the one out and it smelled of gas. So thinking about install I did drop one down the engine bay and that must have been enough. I put the old sparker in and running on all 4. Good deal. Now it needs throttle body cleaning due to low idle.
Old Aug 30, 2014
bluciv's Avatar
Re: New guy from AL
Time for a compression test. Missing again.
Old Aug 30, 2014
bluciv's Avatar
Re: New guy from AL
Time to start a thread in general. 190-195 for cylinders 1,2,4 and 65 for cylinder 3. :-(
Old Sep 2, 2014
Hondi's Avatar
Hondi is an unknown quantity at this point
Re: New guy from AL
Nice car!
Old Sep 10, 2014
bluciv's Avatar
Re: New guy from AL
Thanks.
Old Sep 10, 2014
bluciv's Avatar
Re: New guy from AL
I finally checked valve adjustment and all were within spec. Maybe clean valves through intake? I should have spun it over checking cam\valve movement.
Old Sep 10, 2014
Re: New guy from AL
Air pressure check (leakdown test) the low cylinder, see where the loss is leaking out or what isn't sealing.
Old Sep 11, 2014
bluciv's Avatar
Re: New guy from AL
Thanks!! Have a good day!
Old Sep 11, 2014
bluciv's Avatar
Re: New guy from AL
It is definitely an exhaust leak. I might be able to check it out through the exhaust port. I sprayed the exhaust manifold cover and any bolts I could get to with PB Blaster. So it is soaking.
LSC
Jun 22, 2015 11:29 PM
nufc
Legal Questions and the Law
Jun 21, 2015 09:57 PM
Reginator
Jun 17, 2015 07:54 PM
wsking77
Aug 29, 2001 05:34 PM
