Speaker leaks water into car when it rains....
Old Aug 5, 2014
coachkapps's Avatar
coachkapps is an unknown quantity at this point
I've done a few searches on here. Found a little info, but would like a little more if I can.
2007 Civic - I replaced factory front speakers. After doing that my car basically flooded (left it outside as we went on a week vacation - rained heavily that whole week).
I've recently figured out that water from the outside window/glass is doing as it normally should, and is running down inside the door. However, this is where I'm confused, as it is somehow running/dripping onto the speakers, wiring, etc, and getting on the door panel side of things. It then seeps into the interior very easily along the bottom of the door.
I've taken the panels off, taken the speakers out, and checked to see what's going on. When I put water onto the window on the outside, I can see it dripping heavily down into the door as it should, but what I'm not sure is what mechanism SHOULD be there to prevent it from getting into the speaker area/inside the car. Is there a part I removed with the factory speakers? Is there is a way to divert the water away from the speakers and wiring?
Thoughts and suggestions please? Thanks in advance!
Old Aug 5, 2014
Re: Speaker leaks water into car when it rains....
Where's the plastic liner that was behind the door panel? Is it intact? Are there gaps in the sealer? Does it channel water to the lower set of holes so water stays away from the door panel?
Are there any plastic rain protectors available to cover the tops of the speakers?
mattdoc
Mar 14, 2017 12:10 PM
LionSpratt
Jan 29, 2017 11:07 PM
mistermenphis22
Apr 3, 2016 08:06 AM
ZSKCivic01
Nov 4, 2001 08:47 PM
Importracer
Nov 4, 2001 07:50 AM
