Overheated now is running rough and losing Oil
Old Jul 31, 2014
DohcLs's Avatar
DohcLs is an unknown quantity at this point
I overheated and now she is running rough. Any thoughts what it coulud be? The Sparks plugs have almost 120,000 miles on them.
Old Jul 31, 2014
Poopies's Avatar
Super Moderator
re: Overheated now is running rough and losing Oil
Could be a warped head. Why did it overheat?
Old Aug 3, 2014
DohcLs's Avatar
I think it was just my imagining it.. Its running ok.. I was low on Fluid. Thanks for the reply.
Old Aug 3, 2014
GolNat's Avatar
Prelude Owner
I would replace the plugs, they are due. NGK or Denso, not Bosch.
Old Aug 3, 2014
kinakoes2's Avatar
*watches temp gauge like a hawkboss* :D
kinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of light
No worries... he'll be back.
Old Aug 4, 2014
BlueEM2's Avatar
Whachya lookin at?
Hmm... There is a reason it was low on fluid...
Old Aug 4, 2014
DohcLs's Avatar
Update: Now im losing oil.. a half a quart every 200 miles.. There is no visible leaks, no smoke, No oil in the coolant. the Car seems to be slightly down on power but i cant confirm it. ITs still running good. What should be my first step? a Leakdown test? Im devastated.
Old Aug 4, 2014
Just how hot did it get?
Collapsed rings?
Compression test...even though I know that cannot evaluate oil control rings, but it's a starting point.
EDIt: Oh, and...um...head gasket is blown.
Maybe needs a fan switch too.
Old Aug 4, 2014
kinakoes2's Avatar
Re: Overheated now is running rough and losing Oil
Using proper viscosity oil? 0W20 is Honda-endorsed, but in a worn motor or one with a stuck ring or two, it'll may get spit out a bit faster than the 5W20.
zaboomafoozarg
May 30, 2015 09:21 AM
Allecr3
May 22, 2015 01:24 PM
ywgflyer
May 15, 2015 05:05 PM
crowtoo
May 11, 2015 06:50 PM
deus-ex
Apr 13, 2015 12:29 PM
