Valve cover gasket for 2010 1.8l
http://www.hondaautomotiveparts.com/...VER+%281.8L%29
Needed for upcoming valve adjustment, my 05 had a huge set when I had the timing belt done. Only see one gasket for this model.
Is it just a single gasket then ??
Thanks,
Thanks,
Re: Valve cover gasket for 2010 1.8l
Single rubber worm, that's it.
Yours will probably still be nice and pliable when you get it apart.
Small dabs o' silicone where the chain case meets the head.
I made another order recently, grabbed a set of plugs and the valve cover gasket for future use.
Going to get 4 more qts of Castrol GTX before it goes off sale Thursday. Will have enough for 4 changes at that point.
Thanks for info on the gasket.
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
JohnnyBxo
16
May 9, 2015 05:53 PM
