01 Civic CA emissions
Old Jul 2, 2014
SandSquid's Avatar
SandSquid is an unknown quantity at this point
My 01 Civic LX 2D 4AT has developed the apparently common crack in the exhaust manifold. My emissions sticker under the hood is a CARB compliant label but when I looked up my VIN number at the Honda website it states that my emissions is KA (49 State). I obviously want to get a new converter that will pass CA smog tests so my question is, do I buy a KL (CA) converter or do I buy a KA converter since that is what is installed. The difference between a OEM KL and a OEM KA is about $160 so I’d like to buy a KA if possible! I appreciate any and all help!
Old Jul 2, 2014
Poopies's Avatar
Super Moderator
Re: 01 Civic CA emissions
Under what state is your car registered? Does it require emissions testing?
Old Jul 2, 2014
SandSquid's Avatar
I live in CA and it has passed all emissions tests up to date (even after the crack started).
Old Jul 2, 2014
At minimum you need a California CARB OBD2 approved cat if you go aftermarket.
If you go with factory/OE you ought to use a parts catalog where you can enter your VIN to look up the parts, let the catalog pick the right choice.
If you really have a KA emissions car, I'd expect you should have a KA cat since that was what the car was originally equipped with from the factory.
Disclaimer: I'm not a Californistan licensed smog tech, and I don't live in Californistan.
cloudguy
Apr 28, 2015 05:02 AM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
bahena08
Apr 11, 2015 05:09 PM
silvervtec01
Nov 4, 2001 06:56 PM
WeRkX
Nov 1, 2001 10:33 PM
