2002 Civic EX 5spd cruise control wont turn on
Hello,
My cruise control on my 02' EX refuses to turn on. when i push the button on the dash, nothing happens, no lights turn on. If this makes a difference, the dash lights that illuminate the name "cruise" don't work either. What could be the issue?
Thanks so much
Thanks so much
Re: 2002 Civic EX 5spd cruise control wont turn on
Some common stuff I've seen:
Blown fuses
the 2 bulbs burn out in the cruise main switch by your left knee (switch still works, just has no lights), OR the switch was left disconnected after someone was in the dash
the brake light switch has a set of contacts specifically for the cruise control, occasionally they go bad or get out of adjustment
the cable for the cruise can break its 'wheel' on the throttle shaft
and the control unit causes the cruise to quit randomly when it's being used.
And I hear that LED taillights can screw with the cruise.
Get yourself a wiring diagram, a shop manual, and some test equipment and git to diagnosing!
Blown fuses
CarStuff
Dec 6, 2020 12:52 PM
smmahan
Apr 15, 2015 08:17 PM
