CIVIC Newbie with some simple Questions
I just bought a 1998 Civic EX coupe automatic with 236,900 miles. One owner car, seems to run pretty well. Has a check engine light took it the the amazing tech at autozone
they said it will need a catalytic converter and it said transmission is out of its shift range. It seems to be shifting perfectly Also and big question here, I have 18s from my old car with universal rims will they fit it was on a 5X110 before.
they said it will need a catalytic converter and it said transmission is out of its shift range. It seems to be shifting perfectly Also and big question here, I have 18s from my old car with universal rims will they fit it was on a 5X110 before. If you think a good mechanic is expensive, try hiring a bad one
Re: CIVIC Newbie with some simple Questions
Welcome!
What was the actual code number?
Will your 5x110 bolt pattern wheels fit on a 4 bolt car?
Thank you for the warm welcome and quick response I had 5X110 on my soul, which is what is was on before and I've never had a 4 bolt wheel in my life but these are universal and the seller seemed to think it would fit I'm going to upload a picture and as for the code it's in thus car which is 30 miles away but I will get it hopefully tomorrow.
http://adaptitusa.com/referencebook.htm
i use this guide for bolt patterns and other helpful info.
When they say its universal they don't mean bolt number wise. If it's 5 bolt universal than usually it's the 5x110 pattern or the 5x100 (Honda Toyota etc). Same with the universal 4 bolt patterns 4x110 and 4x100 (Honda Toyota etc)
The 1970-2005 had the 4x100 bolt pattern unless the 5 bolt pattern conversion was made.
CarStuff
Dec 6, 2020 12:52 PM
AB
17
Nov 8, 2001 09:54 PM
