HID Fog Lights Help
Old Apr 24, 2014
wagstaff13's Avatar
wagstaff13 will become famous soon enoughwagstaff13 will become famous soon enough
Unhappy HID Fog Lights Help
Just installed 6000k 35W hids in my fog lights. 2005 em2.
However, only one light will come on at a time. When I turn the switch on, either the left or the right side will come on. Never both.
Everything worked fine before i got the hids. Whats wrong?
Old Apr 25, 2014
Poopies's Avatar
Super Moderator
Re: HID Fog Lights Help
What do you mean either will turn on? What do you do differently?
Old Apr 25, 2014
you're not running a relay harness, are you?
Old Apr 25, 2014
wagstaff13's Avatar
When I turn the switch on, only one turns on at a time. Its random. Sometimes the left comes on, sometimes the right, but they never both come on at the same time.
To be honest.. I'm not 100% sure. Im pretty sure I'm not, and I took it out of the fog light harness when I first hooked them up. Everything worked before I put in hids.
Old Apr 25, 2014
GolNat's Avatar
Prelude Owner
Maybe your pulling to many amps through your relay now that you have HID ballasts hooked into it rather then just bulbs.
What amp rating is your relay?
Old Apr 26, 2014
wagstaff13's Avatar
Stupid question, but how do I tell? I'm pretty sure I cut out the relay. But they are ebay oem fog lights if that makes a difference.
Another thing, most of the time my stereo shuts off and resets when I turn my fog switch on. It didnt do this until I put in HID's. I have a brand new battery and alternator.
Old Apr 26, 2014
Poopies's Avatar
Super Moderator
Where are they getting their power?
Old Apr 26, 2014
GolNat's Avatar
Prelude Owner
Relay would have looked like one of these:
Old Apr 27, 2014
wagstaff13's Avatar
From the 12V cigarette lighter thing. Do you think it can't supply enough power? If so, where should I hook it up?
Old Apr 27, 2014
Poopies's Avatar
Super Moderator
Ok, the way my headlights are set up is like this:
The bulbs are powered by the ballasts which are powered by the relay which draws its power directly from the battery. The original power source for the OEM bulbs is only used as a switch. You might want to try to getting them powered directly off the battery if you can.
Old Apr 27, 2014
GolNat's Avatar
Prelude Owner
Lighter is only rated at 7.5 amps. That's not enough.
Old Apr 27, 2014
Not nearly enough amperage. Maybe as a signal wire for the relay, but keep in mind that ballasts take 12vdc and basically does some voodoo magic to send (well, my ballasts do) 20kV to the HID bulbs. Wire in a relay where pins 85-86 can be to/from whatever source you want with an inline switch, but pin 87 comes from the battery and pin 30 goes to the HIDs
edit: wrong word, plus my tablet is awesome
Old Jun 13, 2014
wagstaff13's Avatar
So I finally got a chance to mess around with them. I connected my fog light directly to my battery, annnnnnndd....... no change
Still, only one will come on a time. And its not always the same side.
What do i do??
Old Jun 13, 2014
GolNat's Avatar
Prelude Owner
So you connected them directly to the battery individually? Not using the relay or wire harness?
XXLUV2EXCELR8XX
Dec 16, 2001 04:56 PM
LuvMyCivic
Dec 12, 2001 10:02 PM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
