HID Fog Lights Help
Just installed 6000k 35W hids in my fog lights. 2005 em2.
However, only one light will come on at a time. When I turn the switch on, either the left or the right side will come on. Never both.
Everything worked fine before i got the hids. Whats wrong?
Re: HID Fog Lights Help
When I turn the switch on, only one turns on at a time. Its random. Sometimes the left comes on, sometimes the right, but they never both come on at the same time.
To be honest.. I'm not 100% sure. Im pretty sure I'm not, and I took it out of the fog light harness when I first hooked them up. Everything worked before I put in hids.
Another thing, most of the time my stereo shuts off and resets when I turn my fog switch on. It didnt do this until I put in HID's. I have a brand new battery and alternator.
Ok, the way my headlights are set up is like this:
The bulbs are powered by the ballasts which are powered by the relay which draws its power directly from the battery. The original power source for the OEM bulbs is only used as a switch. You might want to try to getting them powered directly off the battery if you can.
Not nearly enough amperage. Maybe as a signal wire for the relay, but keep in mind that ballasts take 12vdc and basically does some voodoo magic to send (well, my ballasts do) 20kV to the HID bulbs. Wire in a relay where pins 85-86 can be to/from whatever source you want with an inline switch, but pin 87 comes from the battery and pin 30 goes to the HIDs
edit: wrong word, plus my tablet is awesome
So I finally got a chance to mess around with them. I connected my fog light directly to my battery, annnnnnndd....... no change
Still, only one will come on a time. And its not always the same side.
What do i do??
What do i do??
