Timing belt change-what else should be done? SUCCESS
Old Feb 22, 2014
gotcivicback's Avatar
gotcivicback is an unknown quantity at this point
140K miles- Going to have the dealer change my timing belt, what else should be done while they are doing it? Rough estimate on cost? This is the first time I have had it done-too much for me for a diy.
Old Feb 22, 2014
GolNat's Avatar
Prelude Owner
Re: Timing belt change-what else should be done?
To save some money you could buy OE parts online and find a dealer/shop that will instal them.
I would replace:
Timing belt
Timing belt tensioner
Water pump
Crank Seal
Cam seal
Valve cover gasket set
Accessory belts (since they will be off)
Old Feb 22, 2014
mikey1's Avatar
a dealership won't do that.....that would be like bringing your own food to a restaurant and asking them to cook it for you,
to the original poster, i would replace the timing belt and timing belt tensioner, 2 drive belts, cam seal and crank seal seeing as they are cheap, and that's it if your tight on cash,
if you want to spend extra money and have the money to spend, then replace your water pump, thermostat, and coolant while your at it,
Old Feb 23, 2014
GolNat's Avatar
Prelude Owner
I must have a nice dealer near me then. As long as its a honda part they don't care where I got it from.
Old Feb 23, 2014
Thanks guys, I'll bite the bullet and get it all done. I'll post the cost after a few brews...
Old Mar 11, 2014
Got a quote to : Replace timing belt & tensioner, water pump, thermostat, coolant, crank & cam seals, valve cover gasket, and 2 drive belts, $1465.
Does that sound reasonable?
Old Mar 11, 2014
No.
Wait.
Depends on your market.
IMO, that's WAAAAAY high for my area.
Old Mar 11, 2014
GolNat's Avatar
Prelude Owner
Originally Posted by gotcivicback
$1465.
That's high for me also.
When my tension pulley broke and I needed a new head with all new valve train my total was just under $1500. With all the parts you said plus a new radiator.
Old Mar 11, 2014
Holy ****, 1465 for a timing belt? I paid less when I decided I was frustrated and had another shop replace valves/hg for me.
Local dealership quoted me ~$650 for a timing belt (along with water pump, tensioner, ac/ps belt) job.
Old Mar 11, 2014
kinakoes2's Avatar
*watches temp gauge like a hawkboss* :D
kinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of light
Originally Posted by ezone
No.Wait. Depends on your market.
That's way high for here, and they raep you raw here (one dealer on an island with lots of very proud indies).
I'd shop around... unless that shop has the best rep you can find for timeliness and you see an itemized RO, I'd look elsewhere. Even if you had to drive 100 mi and find something to do all day, that's worth $500-$600 savings to me...
Old Mar 12, 2014
CraigW's Avatar
I looked it up, my online 100% OEM parts list for my 05 was about $200. Can't remember the labor but it was done by an independent top technician.... and was a very fair price as always.
Old Mar 12, 2014
crxmanpat's Avatar
Pusher Jets Rule!
crxmanpat has a spectacular aura aboutcrxmanpat has a spectacular aura about
For that kind of money, they should be doing the head gasket too (which is typically when all this other stuff gets replaced at the same time).
Old Mar 12, 2014
a reach around, and a kiss when it's all over.
Old Mar 12, 2014
crxmanpat's Avatar
Pusher Jets Rule!
Lol!
Old Mar 12, 2014
civicloco's Avatar
civicloco is an unknown quantity at this point
Holy crap! I bought a 2005 LX last year for $1800.00 with 199k miles and the
car had the timing/water pump, seals,.etc..done at 160k.
Old Mar 12, 2014
mikey1's Avatar
holy crap,
i will do it for $700 parts included,
and i will give you a 100K mile warranty
Old Mar 13, 2014
holy crap,
Thanks for the input everyone. I am waiting for another quote, both are from dealers, if not any lower I will look for an independent service guy. The car runs great now and I am not putting many miles on it so no hurry to get screwed. Thanks again........
Old Mar 13, 2014
mikey1's Avatar
i wouldnt really suggest that, i have heard of many independent shops botching these timing belt jobs
Old Mar 13, 2014
Where are you located??
Old Mar 14, 2014
I am in Southern California. I sell printed products and have had a customer for 20 years, U S Foreign Auto, so my brain finally clicks, I call him and he knows what needs to be done, $600 or so. I forgot my Honda was a foreign car,,,,Thanks again for all your help. btw, one dealer never bothered to give me a price and I called and faxed over the quote information twice...
Old Mar 14, 2014
CraigW's Avatar
Sounds good... I would confirm oem parts and not a cheap kit though.
Old Mar 23, 2014
Re: Timing belt change-what else should be done? SUCCESS
If the board had a party I would bring the beer. Thanks to everyone that helped me saye $745. I had the Timing belt, Tensioner, Water Pump, Drive Belts, (OEM Kit) Oil and Oil Filter and the spark plugs done for $702. The mechanic said the seals were fine, he could have charged me for the work, but said they did not need to be changed. The car runs great.
Old Mar 23, 2014
mikey1's Avatar
that can be arranged.....better make it 4 or 5 cases
i will have one by myself
Old Mar 23, 2014
Old Mar 24, 2014
jamesking91's Avatar
jamesking91 is an unknown quantity at this point
Fixes on Civics are super easy to do yourself. I changed all my belt (timing, a/c, and power steering) in 2 hours. Just make sure that you have your car in time before you put everything back together.
mattdoc
Mar 14, 2017 12:10 PM
EdGasket
May 25, 2015 01:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
