Backup camera 7th gen dashboard reverse light wire color & harness location
Old Jan 19, 2014
alex_nyc's Avatar
alex_nyc is an unknown quantity at this point
Hi, my searching didnt come up with anything.
can someone please tell me which harness upfront has the reverse light and what color are the wires? For a Backup camera installation.
reverse light wire color:
harness location, etc:
7th gen 2003 civic sedan EX Auto
Thank You! Have a Great day!
Old Jan 19, 2014
Re: 7th gen dashboard reverse light wire color & harness location
What's the goal here? Backup camera or something?
What year is the car?
EX, LX, or what?
sedan or coupe
auto or manual trans
Old Jan 19, 2014
The underdash fusebox is the junction point for many harnesses.
Rev + circuit is a green wire into and out of the fusebox at these points:
Connector D, terminal 8
Connector P, terminal 1
Auto and CVT trans car has a REV relay behind the glovebox, that would be easy access.
Old Jan 19, 2014
alex_nyc's Avatar
yes, Safety back up camera. 7th gen 2003 civic sedan EX Auto
Thank You!
Old Jan 19, 2014
Ok, the relay in the glovebox should be pretty convenient. Flop the glovebox wide open as if changing cabin filters, you should find a row of relays at the bottom edge. My pic shows it to be the black relay on the drivers side of the row. Green wire is + output to the reverse lights.
I got a $16 camera off the internet for my backup cam, it's connected to the iMID in the dash.
Mine came with the cable for the camera, it has RCA ends and it had a 3rd wire hanging outside of the RCA jack on each end.
The 3rd wire was supposed to be used to connect to the backup light circuit in the trunk area.
Old Jan 20, 2014
alex_nyc's Avatar
im not sure what iMID is yet, but I have a $24 wireless camera kit plus a $17 video screen. The rear wiring is already done. Hopefully the weather will be warmer tomorrow so I can finish this one & start the next camera in my wifes 2010 civic LX auto 4dr no nav. Do you have the wiring info my 2010?
thanks again
Old Jan 20, 2014
iMID is the information display screen/monitor in the dash of 12 and never Civic.
That's gonna be trickier. Only connector up front is in the fusebox, and only one wire unless you happen to have something plugged into the accessory connector hole (open spot w/6 pins or so at top left of fuse portion when the box is standing upright).
Connector E, terminal 15. Wire color says purple or brown. --- (Brown for sedan?)
Layout is numbered 1-22 across the top, 23-42 across the bottom.
#1 is yellow, start counting from that.... #22 and 42 are both empty.
Pic is of the dash fusebox laying on its side. Fuses are at the bottom when in the car.
Connector E is a long one with a gray cover, the middle of the 3 long ones.
Was that simple enough? LOL
Old Jan 20, 2014
alex_nyc's Avatar
Thank you for your help, yes you made it very easy. Hopefully easy enough for me
Ill give it a try with my test light otherwise I might have to run a long wire from the backup light harness.
Old Jan 20, 2014
alex_nyc's Avatar
Thank You!
Some FYI info to share.
I took this pic of the wires, harness & relays from behind the glove box.
The green wire to the bottom left is the reverse wire, it has power only when the key is on -while in reverse. You can do this with the engine off.
There were 2 green wires so get your test light ready.
The black relay on the bottom right in the reverse light relay.
Old Jan 20, 2014
Test light? That's like a 4 letter word! That's not allowed 'round here!
Seems like there's only about 3 people that even know what one of those is AND knows how to use it.
Old Feb 16, 2018
bryanbrazil's Avatar
bryanbrazil is an unknown quantity at this point
How do I figure out which connectors are D and P? Here's a photo of my under dash fuse box. I'm trying to connect the reverse signal wire on my head unit to the reverse wire coming out of the fuse box. Thanks!
https://i.imgur.com/9bDAShY.jpg
Old Feb 16, 2018
Re: Backup camera 7th gen dashboard reverse light wire color & harness location
Check out the pic in this post:
https://www.civicforums.com/forums/2...-question.html
Old Feb 16, 2018
Perfect, thanks!
Old Apr 15, 2018
Scottboyd02's Avatar
Scottboyd02 is an unknown quantity at this point
Old Apr 15, 2018
Originally Posted by Scottboyd02
Where is connector D or P like described above?
Click the link in reply #12
IIRC the lead by the relay behind the glovebox is only on manual trans cars
Also....you could just run a wire from the back of the car, lay it along with the camera wiring.
Old Apr 15, 2018
Feel like an idiot saw post 12 right after I posted. I do have a manual. (05 EX Coupe) Reverse lead by relay didn’t jump out at me, is it a large gauge wire or hidden under something?
I’ve already wrapped my power, ground and video cable together with electrical tape. So that’s why I want to pick up the reverse signal by the dash.
I assume the terminals are numbered on the connectors right?
Old Apr 15, 2018
You're gonna have the camera powered all the time? May as well leave the monitor powered too, kinda like having a rear view mirror camera LOL
No. I ALWAYS use a wiring diagram and check wire colors.....even when a connector is labeled....because they don't always follow the rules.
Also.....I mentioned IIRC (If I recall correctly) about the relay....and I finally got to look at a real diagram.....the auto trans cars use the reverse relay, not manual tans. I CRS. Sorry bout that.
Wire color is green, into and out of the fusebox
Same circuit also passes through the big gray harness junction connector in front of the glovebox/PCM area above the relays (cavity 7, one side is green, other side is green/white)
Old Apr 15, 2018
Appreciate the help. The green/green-white wire that passes through that big gray harness junction in front of the ECU will be easy to tap!
Still have those diagrams out? Since I’m right there which one is the VSS (vehicle speed sensor) I read that it was right there behind the glove box a blue white wire. It come out of that gray junction as well?
Powering the camera with the accessory wire so it’s only on when the car is on. Modern head units are designed to function this way. So yes I can switch to the reverse camera while driving Same way I have my Avalanche hooked up. Running Pioneer NEX head units.
Old Apr 18, 2018
I pulled that big gray junction connector out too look at it and the blue/white turns into white/green! So that should be the VSS!
While I had it out I noticed that there’s is a green/white wire that turns into a green wire on the bottom. Like mentioned above. However there’s also a green wire that turns green/white on the bottom. Time to bust out the multimeter to find out which is which.
OK so it’s the green wire the turns into a green/white wire on the bottom. To clarify the green wire comes in through the top of the big gray junction connector and comes out the bottom a green/white wire. It’s further back on the connector towards the firewall.
05 civic ex 5spd
Old Apr 18, 2018
STOP HERE!!!!!
05 civic ex 5spd
Um, you're posting in 2 different threads?
The VSS signal circuit has no solid green wires at all. NONE
Old May 29, 2021
04 auto lx, for me it was the green/silver wire not the green/black one. I removed the entire glove box and the metal bracket it attaches to, so I could get at the wires under the black relay.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Jon-Ohio
Jun 30, 2018 08:10 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
galaga3
Oct 1, 2001 01:56 AM
