Backup camera 7th gen dashboard reverse light wire color & harness location
Hi, my searching didnt come up with anything.
can someone please tell me which harness upfront has the reverse light and what color are the wires? For a Backup camera installation.
reverse light wire color:
harness location, etc:
7th gen 2003 civic sedan EX Auto
Thank You! Have a Great day!
Re: 7th gen dashboard reverse light wire color & harness location
What's the goal here? Backup camera or something?
What year is the car?
EX, LX, or what?
sedan or coupe
auto or manual trans
EX, LX, or what?
sedan or coupe
The underdash fusebox is the junction point for many harnesses.
Rev + circuit is a green wire into and out of the fusebox at these points:
Connector D, terminal 8
Connector P, terminal 1
Auto and CVT trans car has a REV relay behind the glovebox, that would be easy access.
Thank You!
Ok, the relay in the glovebox should be pretty convenient. Flop the glovebox wide open as if changing cabin filters, you should find a row of relays at the bottom edge. My pic shows it to be the black relay on the drivers side of the row. Green wire is + output to the reverse lights.
I got a $16 camera off the internet for my backup cam, it's connected to the iMID in the dash.
Mine came with the cable for the camera, it has RCA ends and it had a 3rd wire hanging outside of the RCA jack on each end.
The 3rd wire was supposed to be used to connect to the backup light circuit in the trunk area.
thanks again
im not sure what iMID is yet
2010 civic LX auto 4dr no nav.
Connector E, terminal 15. Wire color says purple or brown. --- (Brown for sedan?)
Layout is numbered 1-22 across the top, 23-42 across the bottom.
#1 is yellow, start counting from that.... #22 and 42 are both empty.
Pic is of the dash fusebox laying on its side. Fuses are at the bottom when in the car.
Connector E is a long one with a gray cover, the middle of the 3 long ones.
Was that simple enough? LOL
Thank you for your help, yes you made it very easy. Hopefully easy enough for me
Ill give it a try with my test light otherwise I might have to run a long wire from the backup light harness.
I took this pic of the wires, harness & relays from behind the glove box.
The green wire to the bottom left is the reverse wire, it has power only when the key is on -while in reverse. You can do this with the engine off.
There were 2 green wires so get your test light ready.
The black relay on the bottom right in the reverse light relay.
https://i.imgur.com/9bDAShY.jpg
Re: Backup camera 7th gen dashboard reverse light wire color & harness location
I’ve already wrapped my power, ground and video cable together with electrical tape. So that’s why I want to pick up the reverse signal by the dash.
I assume the terminals are numbered on the connectors right?
Feel like an idiot saw post 12 right after I posted. I do have a manual. (05 EX Coupe) Reverse lead by relay didn’t jump out at me, is it a large gauge wire or hidden under something?
You're gonna have the camera powered all the time? May as well leave the monitor powered too, kinda like having a rear view mirror camera LOL
No. I ALWAYS use a wiring diagram and check wire colors.....even when a connector is labeled....because they don't always follow the rules.
Also.....I mentioned IIRC (If I recall correctly) about the relay....and I finally got to look at a real diagram.....the auto trans cars use the reverse relay, not manual tans. I CRS. Sorry bout that.
Wire color is green, into and out of the fusebox
Same circuit also passes through the big gray harness junction connector in front of the glovebox/PCM area above the relays (cavity 7, one side is green, other side is green/white)
Appreciate the help. The green/green-white wire that passes through that big gray harness junction in front of the ECU will be easy to tap!
Still have those diagrams out?
Since I’m right there which one is the VSS (vehicle speed sensor) I read that it was right there behind the glove box a blue white wire. It come out of that gray junction as well?
Powering the camera with the accessory wire so it’s only on when the car is on. Modern head units are designed to function this way. So yes I can switch to the reverse camera while driving
Same way I have my Avalanche hooked up. Running Pioneer NEX head units.
Since I’m right there which one is the VSS (vehicle speed sensor) I read that it was right there behind the glove box a blue white wire. It come out of that gray junction as well?Powering the camera with the accessory wire so it’s only on when the car is on. Modern head units are designed to function this way. So yes I can switch to the reverse camera while driving
Same way I have my Avalanche hooked up. Running Pioneer NEX head units.Last edited by Scottboyd02; Apr 15, 2018 at 09:14 PM. Reason: Correction
I pulled that big gray junction connector out too look at it and the blue/white turns into white/green! So that should be the VSS!
While I had it out I noticed that there’s is a green/white wire that turns into a green wire on the bottom. Like mentioned above. However there’s also a green wire that turns green/white on the bottom. Time to bust out the multimeter to find out which is which.
OK so it’s the green wire the turns into a green/white wire on the bottom. To clarify the green wire comes in through the top of the big gray junction connector and comes out the bottom a green/white wire. It’s further back on the connector towards the firewall.
05 civic ex 5spd
05 civic ex 5spd
STOP HERE!!!!!
05 civic ex 5spd
05 civic ex 5spd
The VSS signal circuit has no solid green wires at all. NONE
Some FYI info to share.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Jon-Ohio
Jun 30, 2018 08:10 PM
