2007 Si won't start
Old Jan 19, 2014
Jean-Luc's Avatar
Jean-Luc is an unknown quantity at this point
2007 Si won't start
I have a 2007 Honda Civic SI 2.0L sedan,when i insert my key in the ignition switch there is no (green key light symbol/immobilizer light) key symbol in the dash board and when i try to start the car the engine (crank) turnover but wont start.Wondering if i need a new immobilizer or what could be the possible problem.
Old Jan 19, 2014
Re: 96 Civic questions
This really needed to be in a thread of its own.
Jamaica? Is this a USA market car?
If the car was built to be in another country, I may not be of help. I only have info for US market cars.
The green light should come on briefly, and then extinguish.
SYSTEM DESCRIPTION
Immobilizer Indicator
The immobilizer indicator is on the instrument panel.
When you insert a programmed ignition key (master or
valet) into the ignition switch, and turn the switch to ON
(II), the indicator flashes once and then goes off. At this
point, the engine can be started by turning the ignition
switch to START (III). Unlike previous systems, the
indicator does not come on when you turn the ignition
switch to LOCK (0).
If you insert a nonprogrammed ignition key into the
ignition switch and turn the switch to ON (II), the
indicator comes on for 2 seconds and then starts to
flash.
You see no green key symbol illumination on the tach cluster at all?
Old Jan 19, 2014
Re: 2007 Si won't start
Ok, moved to a thread of its own. Carry on.
Old Jan 19, 2014
Jean-Luc's Avatar
[QUOTE=ezone;4656294]Ok, moved to a thread of its own. Carr
Sorry to post in this thread. its because i am new to the system so my apology once more
Old Jan 19, 2014
Jean-Luc's Avatar
SYSTEM DESCRIPTION
switch to LOCK (0).
flash.
yes no green key light symbol illumination in the dash board at all
car usually start fine with the original key but suddenly stop start
Last edited by Jean-Luc; Jan 19, 2014 at 12:41 PM. Reason: yes is a usa market car
Old Jan 19, 2014
Does the check engine light come on?
Does the rest of the dash light up like it normally does, or is anything else apparently wrong? (observe and assess all electrical operations in the car for possible related problems)
Gauges,
Exterior Lights
Interior lights
Chimes
Door-open and trunk-open warning lights
keyless, security, and horn (security and panic mode)
power door locks
dash light brightness control
(all these items use the B-CAN network)
Trying to figure out if this might be isolated to the immobilizer components or if other items might be affected too.
You have the key itself,
the immobilizer receiver/control unit in the steering column,
the IMOES unit (part of the MICU, which is built into the dash fusebox assembly)
the PCM
and all wiring between the units.
All parts are heavily dependent on data communications between the units: F-CAN and B-CAN data communication networks.
I would probably begin by inspecting every fuse in both fuse boxes, and I'd use a test light or meter to speed the checking.
dash: Fuse 2, 10, 38
engine compartment: fuse 23, 19,
And all the rest of the fuses in both boxes
Jokerhogan
May 9, 2015 02:52 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
black2k1vtec
Dec 6, 2001 09:49 PM
