1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
help, water issues
Old Jan 6, 2014
zemerin's Avatar
zemerin is an unknown quantity at this point
help, water issues
I was driving to the bus stop this morning and it was raining. I go through a puddle I didn't really notice too well, car suddenly stops. Figured that water prob got into the CAI, so I pull it to the side out of the puddle and check the spark plugs. They don't seem to be wet or anything. I let the car off for 15-20 minutes and nothing; no crank. I did have some attempt but no luck.
What would be the problem here? I'm hoping the pistons didn't break or anything. Any ideas? 5th gen Civic EX coupe.
Thanks.
Old Jan 6, 2014
Re: help, water issues
Remove the spark plugs, then try to crank it.
Next step is to use a socket/wrench on the crank bolt to see if the engine is locked up.
Old Jan 6, 2014
zemerin's Avatar
Update: I don't have time to crank the engine or look at it thoroughly right now, but I went to the car just to see if I had any luck. Tried to start, and it cranked for a second and it seemed like it wanted to start but then it stopped. No crank after that.
Old Jan 6, 2014
So it went "ruh ruh woop.........." *silence*
Pull the plugs out and see if it will crank.
Watch, it may blow a load of water out.
Screw plugs back in, See if it will run.
NOTE: If there was water in the cylinders, then there will be water in the oil which is bad!
See (listen) if noisy and/or runs bad
If runs bad, then compression test and check for bent rods.
Old Jan 6, 2014
zemerin's Avatar
Pretty much, it was kinda like a subtle crank but it felt like it could start if it kept cranking.
So pull the spark plugs and see if it cranks and if water comes out?
I'll try it again before I go out.
And yeah my worst concern is a bent rod or the piston being messed up. I'm gonna end up changing the oil if I can get it to run and take it home.
Old Jan 6, 2014
Correct.
You cannot compress liquid.
The connecting rod is the weak link. They bend if the crank keeps turning when the piston can't make its full stroke
Pray to the deity of your choosing.
Old Jan 6, 2014
zemerin's Avatar
Worse case scenario, how much would an engine be, with the swap?
Old Jan 6, 2014
Seriously: How long is a stick?
A million would probably cover it.
Old Jan 7, 2014
zemerin's Avatar
Yep, she's dead. Two pistons ain't moving. New engine time.
Old Jan 7, 2014
You might want to consider getting rid of the water-sucking intake setup.
Old Jan 7, 2014
zemerin's Avatar
thats for sure, definetly not letting this happen again. ill probably end up just cutting the tube so it stops by the side instead of coming through the shell of the car.
Supramk3
May 11, 2015 07:55 PM
markp94
Apr 30, 2015 09:19 PM
Panda
Mar 1, 2002 04:32 PM
Diznavis
Feb 27, 2002 09:55 PM
skywalker
Nov 8, 2001 05:04 PM
