gas tank is leaking from the hose that connects to it
Old Dec 22, 2013
lorolia's Avatar
lorolia is an unknown quantity at this point
is this a metal or plastic tank?
My civic is 2005, 5 speed manual, d17a1
there´s a hose clamp that I already checked but it´s tight.
Actually the gas is leaking from the union of the hose to the tank.
What can I do?
Thanks in advance for any help you could provide me.
Old Dec 22, 2013
Re: gas tank is leaking from the hose that connects to it
You mean where the large filler tubes connect to the gas tank?
On a US market 2005 Civic, the fill pipes are steel, the hoses are rubber, the gas tank is plastic.
The hose clamp you already said is tight-- it might be stuck and may need some penetrating oil to free it up, then you may be able to tighten it more.
Or replace the clamps.
HTH
Old Dec 23, 2013
lorolia's Avatar
thanks a lot.
I already fixed it.
I used epoxy bonder automotive line.
You were right the tank is plastic.
Old Dec 23, 2013
i other words, the tank cracked...
sccarally
Texas
May 17, 2015 10:11 PM
mievil
Apr 28, 2015 11:02 PM
deus-ex
Apr 13, 2015 12:29 PM
StealthBlack
Dec 17, 2001 03:13 PM
Lightman
Nov 10, 2001 06:44 PM
