b18b turbo
Old Dec 21, 2013
beastmodeeg94's Avatar
beastmodeeg94 is an unknown quantity at this point
b18b turbo
I have a brand new fully built b18b1 engine that's boosted. I'm having a problem with my oil pressure. When I drive it the highest the oil pressure goes is 25 to 30 psi and thats goin 80mph, n when it's on park, it's around 13 to 15 psi. Is it to low or is this what the oil pressure should be at? My car is throwing out blue smoke which I don't get why because the car has new seals n stuff, could it be because of the turbo because turbo does have a lot of shaft play n it's old. Or can it be running to lean or rich please help n thank you
Old Dec 21, 2013
Re: b18b turbo
I have a*brand*new*fully built b18b1 engine that's boosted. I'm having a problem with my oil pressure. When I drive it the highest the oil pressure goes is 25 to 30*psi*and thats goin 80mph, n when it's on park, it's around 13 to 15 psi. Is it to low or is this what the oil pressure should be at? My car is throwing out blue smoke which I don't get why because the car has new seals n stuff, could it be because of the*turbo*because turbo does have a lot of shaft play n it's old. Or can it be running to lean or rich please help n thank you*
Old Dec 22, 2013
Re: b18b turbo
Oil pressure: 10 PSI for every 1000 RPM is a basic racers rule of thumb.
Smokes blue: Blue is oil burning.
If there wasn't a turbo on it, it would be easier to figure out what's wrong based on the conditions when it smokes.
Yeah a loose/worn turbo can dump a lot of oil and make a lot of smoke. Is the intercooler full of oil? That'd be a clue.
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
justcruzin125
Aug 11, 2015 09:09 PM
