No fuel pressure in 90 civic si
Re: No fuel pressure in 90 civic si
Think it jumped time due to failed cam belt tension-er. Put in a new cam belt and water pump two years ago. Checked the belt the other day. Seems to be really loose.
Thanks for all the help! LOL!
Jumped time due to weak timing belt spring. Low compression in two cylinders. bent valves, Thanks for the help
. Sold it for 425 bucks. did not feel like doing the heads. Thought the civic world would have great support. I was wrong.
I don't recall noticing your posts....Sorry.
Sounds like your real problem was quite far different from fuel pressure.
It should have sounded very wrong during cranking (the sound of the starter working against compression).
CarStuff
Dec 6, 2020 12:52 PM
Jonnie.
Jan 13, 2019 11:21 AM
