check engine code p1316
Old Sep 6, 2013
Toms49ers4life's Avatar
My 7th gen civic
Toms49ers4life is an unknown quantity at this point
Hey everyone I have a 2001 civic dx and yesterday while driving home the car died on me, i waited 5 minutes and started it up and it ran just fine( it was about 102° when i was driving) the check engine light came on with code p1316 spark plug malfunction (missfire)
. I've already tested the ignition coils and all four are good, also changed the spark plugs and oil and air filter can someone please shine some light on how i might fix this?
Old Sep 6, 2013
Re: check engine code p1316
P1316 does not exist for a US spec car.
Try again?
Old Sep 6, 2013
My 7th gen civic
http://www.engine-light-help.com/hon...ine-light.html
That's the code that came up on the scanner!
Old Sep 6, 2013
Again, an 01 Civic cannot have a P1316 code. The code does not exist for that car. The PCM cannot generate that code.
But your scanner can interpret the data wrong.
So try a different scanner before going any further.
(Seriously, it's a big issue with some aftermarket scantools.)
The description for that code in your link has two separate items described under P1316, and both have nothing to do with an 01 Civic. The code is not for that car.
HTH
Old Sep 6, 2013
My 7th gen civic
Okay ill take it to pep boys and have them.read the code.
Also the code will go off on its own so ill have to drive it during the middle of the day when.its hot in order for the car to die and the check engine light will come.back on. Have you heard of anything like that?
Old Sep 6, 2013
I've seen a lot of weird stuff over the years.
Accurate explanations usually come only after figuring out what the issue really is.
Old Sep 6, 2013
The light may go out by itself, but the data should be retained in the PCM memory.
Get the Freeze Frame data too.
Old Sep 6, 2013
My 7th gen civic
Thank you ezone!
Old Sep 6, 2013
I just wrote this in another thread:
I have personally witnessed a couple of Hondas cars do seemingly odd things while obvious misfire issues were happening, yet codes had mysteriously disappeared by the time codes could be checked. Had to read code while the light was on.
Weird things can happen, but there usually is a logical explanation for them....no matter if anyone understands it or not.
YMMV
mistermenphis22
Apr 3, 2016 08:06 AM
tylerginevan
Apr 27, 2015 12:29 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
dooner24
Apr 14, 2015 07:51 PM
bahena08
Apr 11, 2015 05:09 PM
