sticky manual windows
Old Aug 24, 2013
localkineguy's Avatar
localkineguy is an unknown quantity at this point
I have a 1997 Honda DX. my Windows are difficult to roll up and down, to the point where I'm afraid of breaking my plastic window handles. What do you do to clean or lubricate the windows?is my problem with lubrication?
Old Aug 24, 2013
Re: sticky manual windows
I'd grab just about any silicone spray lubricant first.
Spray it heavily into the vertical rubber channels where the glass has to slide.
Work the window up and down as you spray to distribute the lube.
Old Aug 25, 2013
What channels? Do I have to take off teh inner panel?
Old Aug 25, 2013
Originally Posted by localkineguy
What channels?
Look and think, this should be self explanatory.
Hell....
Glass run channel
From Wikipedia, the free encyclopedia
A glass run channel is a groove, normally made of http://en.wikipedia.org/wiki/Rubber or http://en.wikipedia.org/wiki/Plastic, that is found around http://en.wikipedia.org/wiki/Window (most commonly http://en.wikipedia.org/wiki/Car_windows).http://en.wikipedia.org/wiki/Glass_run_channel#cite_note-1http://en.wikipedia.org/wiki/Glass_run_channel#cite_note-2http://en.wikipedia.org/wiki/Glass_run_channel#cite_note-3 The primary purpose of a glass run channel is to provide a http://en.wikipedia.org/wiki/Seal_%28mechanical%29 for the window
This page has a pic: http://en.wikipedia.org/wiki/File:Gl...uck_window.jpg
Not if hosing it from above works.
Old Aug 25, 2013
EDIT: Damn, that copy and paste didn't work too well.
Old Aug 25, 2013
Tried it, doesn't seem to make a difference. I will also say that the stickiness varies with window height. While I roll the window down, it starts off easy and then gets sticky and then gets easy again.
Old Aug 25, 2013
got2run5's Avatar
got2run5 will become famous soon enoughgot2run5 will become famous soon enough
Look at the front speaker DIY and it will show you how to take the door panel off and then grease the thing the window slides on.
Old Aug 25, 2013
CraigW's Avatar
Maybe your regulator is tight in spots, use some white grease on it. I just keep rubber tracks clean it is actually pretty slick on it's own when clean.
Old Aug 27, 2013
I have to eat crow here, and say that the silicone spray lubricant did help my windows stickiness problem. I guess I just needed to wait for the silicon to dry! Thanks ezone
Old Aug 27, 2013
Well, that confirms where the problem lies.. now, what to do about it?
You will probably need to respray whenever the window starts feeling tight again. Most people will do this and live with it, no further work involved.
Next (drastic) step would be to seriously clean the rubber channel seals, or replace them. Years of dirt accumulation is what normally makes the seals drag on the glass.
Old Aug 29, 2013
I think I'll jus spray, the aged plastic pieces might not pop off nicely if I were to take the door panel off.
Dangerousjordan
Jul 27, 2015 03:43 PM
breanna_17
Jul 21, 2015 04:01 PM
estes53
Jul 20, 2015 10:43 PM
ballmich
Jul 9, 2015 11:59 AM
ezone
HIDs and Retrofitting
Jul 4, 2015 12:44 PM
