Driver side window stopped working
Old Aug 1, 2013
SilverCiv05's Avatar
SilverCiv05 is an unknown quantity at this point
I was installing my door speakers and I couldn't get my passenger window to work. I replaced the fuses and nothing, then realized I had pressed the switch to turn off the passenger window while putting the door back together. So, passenger works again, but now my driver side wont work? I tested the fuse, tried a few different new ones and it still won't work.
It worked fine before replacing the fuse. I've had the car for about two weeks, nothing ever seemed like it was shorting out or struggling before. The only thing was the switch was reversed (had to pull up to roll the window down)
Any ideas?
Old Aug 2, 2013
Re: Driver side window stopped working
Originally Posted by SilverCiv05
The only thing was the switch was reversed (had to pull up to roll the window down) Any ideas?
This part sounds like a human screwed up the wires between the switch and motor. Or put in a non-factory window motor.
(Did the window have one-touch UP instead of down?)
I'll guess ..... see if their twist-n-tape wire splices came apart.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
dennis123
May 3, 2015 03:14 PM
mwwhonda
Nov 7, 2001 07:24 PM
EXWisdom
Nov 5, 2001 10:24 PM
sonsonzai
Nov 4, 2001 12:52 PM
