2002 Civic Ex Stalls Codes P1361 & P1298
Old Jun 6, 2013
ykf7b0's Avatar
ykf7b0 is an unknown quantity at this point
Hello,
I am turning to you for some great guidance regarding my 2002 Civic Ex. Just last night the engine light came on and instantly the engine died. After sitting for a minute or two I was able to get her re-fired although she was running rough. She did smooth out but seemed to be underpowerd. I got my truck and trailer and towed it home and after a long cool down she started up and ran fine, for a short while, then the whole process repeated itself. I rented an OBD II from Autozone today and the codes I extracted were; P1361 TDC Intermittent Interuption
P1298 ELD
My question to you guys is; Is P1361 triggering P1298 and if I replaced the TDC sensor would that alleiviate P1298? Or should I start with the Electric Load Detector?
Old Jun 6, 2013
Re: 2002 Civic Ex Stalls Codes P1361 & P1298
P1361 is for the Camshaft Position Sensor signal had an intermittent interruption.
Recent timing belt job?
Wire connector came loose?
Timing belt still in correct time?
P1298 is for the ELD (just replace it), that's a real common issue by itself but normally does not turn on the CEL. Ignore it for now. The other code is your problem so figure that one out FIRST.
When you are ready, this bulletin has the part number and procedure for replacing the ELD: http://www.crvownersclub.com/TSBs/2005/05-006.pdf
Old Jun 8, 2013
ykf7b0's Avatar
No work has been done recently regarding the timing belt. Today I did install a new TDC/Cam Position Sensor and a new ELD. I have had no reccurances so far concerning the aforementioned problem. I pray I don't but if I do have more issues I will follow up so others might benefit from this thread. Thanks!!!
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
shaejb15
Apr 26, 2015 07:44 PM
smmahan
Apr 15, 2015 08:17 PM
CapYoda
Nov 11, 2001 05:17 PM
