1999 Civic Died On Side of Road !!!
Old May 30, 2013
kaputhonda's Avatar
kaputhonda is an unknown quantity at this point
Was driving to work on a rainy morning when the engine gave out at around 30 mph. I pulled to the side and tried to start it, and after about 5 seconds of straight cranking the engine started again. Acted strange for a couple seconds then acted normal again. About 5 minutes later the engine cuts out once more but didn't start. It's been warm and sunny these past few days and everything is dry. Had it towed to my house to run a few tests which are.
- Fuel Pump; When I turn the key I hear the fuel pump running for a few seconds before turning itself off.
- Fuel Pressure; Loosened the fuel hose before fuel rod near engine and fuel squirted out and shot a far distance.
- Spark Plugs; Removed each spark plug individually and each one seemed to spark fairly strong. Was visible from driver seat on a sunny day.
- Compression; To test compression and make sure It cranks, I removed 1 spark plug and stuck a plastic bag with a screwdriver into the hole and shot right out and seemed to have very strong healthy compression.
- Distributor Cap; From reading previous posts I read to watch out for a white substance.
I opened the distributor cap and saw an almost negligible amount of white powder along with tiny amounts of rust on the bottom of the cap, with some white on the metal on the wheel, and slight white on the 4 metal pieces on the cap itself that the wheel touches to give electric (no idea whats it called hopefully you do).
Plus when I turn the key the check engine light comes on, I hear a click then it turns off.
Jumped the connectors and have a steady check engine light. Not sure if that's code 0 since I read that if it is indeed code 0 then the check engine light will be on with or without the jumper.
Thanks everyone in advance.
Old May 30, 2013
kaputhonda's Avatar
Re: 1999 Civic Died On Side of Road !!!
Update: Checked main relay and works properly
Old May 30, 2013
kaputhonda's Avatar
Update: Installed new distributor and spark plug wires and no change.
Old May 31, 2013
kaputhonda's Avatar
Update: Just installed new spark plugs and no change.
usajags84
15
Aug 19, 2015 03:12 AM
usajags84
May 10, 2015 08:11 AM
bsmiley
Apr 27, 2015 01:27 PM
McD
Apr 16, 2015 10:46 AM
CapYoda
Nov 11, 2001 05:17 PM
