What struts do I need?
I have an 04 VP that is in desperate need of rear struts. Any time I hit the slightest bump, the rear end slides to the right and freaks me out on wet pavement. Knowing I need struts, my question is with my VP having lowering springs, do I need to buy a certain kind of strut or will regular struts work? As you can tell, this is my first lowered vehicle. Any help with any info would be awesome.
Re: What struts do I need?
If the lowering spring makes your car low, make sure its street performance.
Tokico, koni, and kyb are great.
Make sure you get alignment right away
The Honda mechanics I talk with say most of the "settling" that will affect alignment happens very quickly...driving around for a couple hours will take care of it. They recommend an alignment right away. Could be wrong, but that's what they tell me.
I don't know what lowering springs you are using, but make sure the shocks/struts can handle the rate of the springs you use. Your best bet is Koni Sports (yellows). They can handle any spring, including Neuspeed Race. Koni STR.T (oranges) should be able to handle pretty much any other spring than Neuspeed Race. Best thing about Koni, other than the incredible performance, is the lifetime warranty.
Call Chris at Redshift Motorsports in Pennsylvania. I believe he used to work for Honda R&D and is unbelievably knowledgeable.
Day after install (Eibach Sportlines: 1.8in drop). We measured, and at that point, it had dropped the car about 1.2in.
And 2 weeks later. The full 1.8in drop. You can see the car is definitely lower.
Now, when both of us installed our coilovers, they only settle about .1-.2in. I'm guessing that was due to the coilovers having much stiffer springs, that the softer Eibach Sportlines. It makes sense that a softer spring will settle more than a stiffer one.
And to the OP, Koni Yellows are AMAZING shocks. They can handle pretty much any stiffness spring you can find, and also have great damping (stiffness) adjustability. I have a set paired with Ground Control coilovers, and aboslutely LOVE them.
It took my Sportlines a couple days to settle (I do a lot of driving though).
Unless OP is really lowering his car or getting GC's I would go with Tokico's just because of how much of a pain Koni's are to instal on a 7th gen compared to blues. If he really want to go low then Koni's are the way to go!
