A/C and Passenger Side Turning Signal Problems
Old May 3, 2013
jeiro's Avatar
jeiro is an unknown quantity at this point
Hi!
I have a 2001 Honda Civic LX Sedan.
I installed an aftermarket HID kit along with a fog light HID kit some months ago. After I installed them, my passenger side signal light has been working some days, while not working on others. During the day with the lights off, the signal goes into a hyperblinker mode and when driving at night with the lights on, it won't signal. The hazard lights work, but sometimes they are out of sync, with them flashing at different intervals. My Driver side signals work fine though. Essentially my passenger side is either in hyperblinker mode or not working at all.
Now my A/C has been having intermittent problems as well. When im driving on the highway it turns on, but is cuts out every so often. When the lights are on, it either works or won't come on. Even with the lights are off it won't turn on sometimes either.
Could this be a wire grounding problem with the lights? Or a faulty relay or something? Because I am getting full power. My lights and radio are performing fine. Thanks!!!
Old May 4, 2013
Re: A/C and Passenger Side Turning Signal Problems
Revisit the work you just did. 95% of the time, the new install caused the new issue.
Wires, bulbs, whatever.
Check for a simple bad bulb?
That was as clear as mud.
Probably unrelated to the headlight install.
Old May 4, 2013
jeiro's Avatar
Yeah I checked the bulbs, I am probably just going to take everything apart this week and see.
The A/C works and doesn't work. By that I mean that sometimes when I'm driving the fan will just shut off and the air will stop, but if i unclick the A/C button the air comes on fine. The heat works no prob. The A/C just turns on and off when I'm driving like its temperamental. Its like it loses power for a few minutes and then when it regains it, it shoots back on. Its ice cold when it works but I don't know what would be causing that.
Old May 4, 2013
You mean the inside blower fan motor quits?
(Still assuming you mean the blower motor here).....Does it come back on like when you hit a bump?
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
crowtoo
May 11, 2015 06:50 PM
Fastfebur
Apr 22, 2015 01:37 PM
civicPRODIGY
Nov 12, 2001 09:32 PM
GhettoCivic
Nov 12, 2001 03:15 PM
