A/C and Passenger Side Turning Signal Problems
Hi!
I have a 2001 Honda Civic LX Sedan.
I installed an aftermarket HID kit along with a fog light HID kit some months ago. After I installed them, my passenger side signal light has been working some days, while not working on others. During the day with the lights off, the signal goes into a hyperblinker mode and when driving at night with the lights on, it won't signal. The hazard lights work, but sometimes they are out of sync, with them flashing at different intervals. My Driver side signals work fine though. Essentially my passenger side is either in hyperblinker mode or not working at all.
Now my A/C has been having intermittent problems as well. When im driving on the highway it turns on, but is cuts out every so often. When the lights are on, it either works or won't come on. Even with the lights are off it won't turn on sometimes either.
Could this be a wire grounding problem with the lights? Or a faulty relay or something? Because I am getting full power. My lights and radio are performing fine. Thanks!!!
Re: A/C and Passenger Side Turning Signal Problems
Wires, bulbs, whatever.
Check for a simple bad bulb?
Probably unrelated to the headlight install.
Yeah I checked the bulbs, I am probably just going to take everything apart this week and see.
The A/C works and doesn't work. By that I mean that sometimes when I'm driving the fan will just shut off and the air will stop, but if i unclick the A/C button the air comes on fine. The heat works no prob. The A/C just turns on and off when I'm driving like its temperamental. Its like it loses power for a few minutes and then when it regains it, it shoots back on. Its ice cold when it works but I don't know what would be causing that.
crowtoo
May 11, 2015 06:50 PM
civicPRODIGY
Nov 12, 2001 09:32 PM
GhettoCivic
Nov 12, 2001 03:15 PM
