How to properly diagnose bad wheel bearing?
Old Apr 20, 2013
mikey1's Avatar
i replaced my right front wheel bearing about 3 years ago, it was making a very loud "humming" noise that was easy to detect coming from the right front side,
when i jacked the vehicle up, i tried to move the wheel by hand in all different directions, it did not move at all, it was solid,
i took it apart anyway, and sure enough the bearing was shot, replaced it and everything has been fine,
for the last week i have the exact same "humming" noise coming back, only this time its so faint i can barely hear it over the road noise, it seems slightly louder on the right side (again) but its impossible for me to tell 100%,
i dont really want to just guess which side it is, so is there any way to tell for sure without ripping the knuckle off?
or should i just leave it till it gets louder? i dont really like driving around with a bad bearing,
Old Apr 20, 2013
Re: How to properly diagnose bad wheel bearing?
You want me to tell you "by the book", or do you want to hear "how I really do it"?
You sure it isn't tire tread chopping?
Old Apr 20, 2013
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Old Apr 21, 2013
mikey1's Avatar
neither.....i got it
i just jacked up the front end, removed both wheels, had somebody start it and put it in drive while i listened at each wheel/hub,
same bearing as last time.....go figure (yes honda oem)
Old Apr 21, 2013
Great.
Pothole damage or curb damage to the bearing? Water damage? How many miles in those 3 years? (Doesn't really matter, just looking for a possible cause that is out of the ordinary.)
Seems premature. Maybe you should think about baseball...
Old Apr 21, 2013
mikey1's Avatar
about 75,000kms
seems weird this one has failed twice and the left side is still going strong
Old Apr 21, 2013
install issues, maybe? or bad batch... or some ball joints coming loose? who knows...
Old Apr 21, 2013
Some people swear the right side takes more abuse since there are usually more potholes and crap on the edge of a road.
IDK.
Old Apr 21, 2013
mikey1's Avatar
i cant see it being an install issue,
i just removed the knuckle and brought it to honda and they put the bearing in....looks like i will be doing it again
Old Apr 21, 2013
was it ezone pressing the bearing in? or a yung'un? :P
Old Apr 21, 2013
Be careful....I might install his bearing with a "swing press":
The shop door is closed. Nobody will ever know.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
dosmastr
May 5, 2015 12:19 PM
hokiedad4
May 3, 2015 10:06 PM
bsmiley
Apr 27, 2015 01:27 PM
dragonsblood
Apr 27, 2015 12:28 PM
