CV joint?
Old Mar 29, 2013
furia2's Avatar
furia2 is an unknown quantity at this point
CV joint?
Hello, I have a potentially sweet deal for a 2004 Civic but I have to make up my mind asap. I don't really have time to do proper research and tests.
There is a loud clunking(louder than clicking) noise coming from the passenger side. I's most prominent under acceleration in 2nd and 3rd gear. It sounds a lot like a CV, but it doesn't make the noise at low speed when it fully turn the steering. In my experience bad CVs always make most noise at low speed while steering.
Any idea if this can be something more serious? Thanks.
Old Mar 29, 2013
mikey1's Avatar
Re: CV joint?
could be many things,
keep in mind that the transmission is on the passenger side of the car,
i would not buy the car in this condition without getting this diagnosed first
Old Mar 29, 2013
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Re: CV joint?
It could be your compliance bushing on the lower control arm. They are a common problem and will make a clunking sound while driving. You can really notice it going over a speed bump.
It's on the front part of the lower control arm and would look something like the picture below if it were torn.
But like mikey1 said, I wouldn't buy it either unless you had somebody very knowledgeable on these cars look it over. Who knows what else is wrong with it.
Old Mar 29, 2013
furia2's Avatar
Re: CV joint?
Denitely not a bushing. It's a fast clunk under acceleration.
I totally overlooked the fact that the transmission is on the right side. I am used to longitudinal engines.
Old Mar 29, 2013
Matt_75's Avatar
Re: CV joint?
Front engine mount which is mounted to the trans? Another common failure.
Old Mar 30, 2013
mikey1's Avatar
Re: CV joint?
is the noise consistent with the speed of the vehicle?
is the sound worse when going over a bump?
jackoncruzpr
Sep 29, 2015 07:59 PM
Joecrowe
Sep 24, 2015 09:12 AM
bashea
Sep 15, 2015 04:59 AM
EdGasket
Aug 29, 2015 09:58 AM
califcamper
Jul 21, 2015 10:34 PM
