96 civic pinging
Old Feb 24, 2013
Clubby88's Avatar
Clubby88 is an unknown quantity at this point
96 civic pinging
Hello all
I have a 96 honda civic with a D16Y5 SOHC, when ever I accelerate the enging pings a lot I've tried using higher octane fuels and it pings a little less but still pings I was wondering what can I do to stop it
Old Feb 24, 2013
Re: 96 civic pinging
If you really have "ping" and not some other engine noise (many people have no idea what all the different noises sound like):
Check ignition timing.
If ignition timing is off by more than 10 degrees, stop. Don't turn the distributor. Pull the timing cover off and check the cam timing/timing belt timing first.
Stock engine?
Does it drink oil?
Old Feb 24, 2013
Clubby88's Avatar
Well I am pretty sure it's engine pinging
Yes stock engine and yea it drinks oil
Old Feb 24, 2013
thanks for posting one on the right forums, anyway... this is a compliment
https://www.civicforums.com/forums/2...elerating.html
Old Feb 24, 2013
Clubby88's Avatar
Yeh realised I post in the wrong forum then relisted in the correct one sorry
Old Feb 24, 2013
So have you checked the timing yet?
Old Feb 25, 2013
Clubby88's Avatar
Not yet I don't have the gear to do it ? What should be the timing ?
Old Feb 25, 2013
Now you need a service manual, a timing light, a way to jump the SCS, and some specs (specs may be on the emissions sticker).
Is your engine lacking power? Feels anemic? Has no ballz?
Old Feb 26, 2013
Clubby88's Avatar
Well yeh it's only a 1.6 SOHC to me it has no ***** doing a timing belt water pump and service this weekend cos it's due for one but yeh
Old Feb 26, 2013
There's a difference between running right and running blatantly wrong. If you have never been in one that runs right, it might be hard to tell. It shouldn't have any problem keeping up with traffic though. If it were off by a tooth or more, I think it would have a tough time keeping up.
So see if it is out of time before you pull it off (see if all the marks line up proper). Then correct it if it is out.
It would suck if it were out and you reinstall a brand-spankin-new belt out of time.
Old Feb 28, 2013
Clubby88's Avatar
Changed the spark plugs and leads ( with iridium plugs) and now it's not pinging anymore but it miss fires when I'm in third or fourth gear it misses And jumps what could the problem be ?
Old Feb 28, 2013
OK then, figure out why it misfires.
What did the old plugs look like? Were they coated in thick white ash (fouled)?
Old Feb 28, 2013
Clubby88's Avatar
The plugs weren't fouled they just looked like there was rust on them
Old Feb 28, 2013
Cap and rotor?
Old Mar 1, 2013
Clubby88's Avatar
Pulled cap and rotar off and the points on the cap had white build up on there have little chunks takin out of them ?
locozoko
Apr 6, 2002 09:00 PM
Cilvic
Nov 15, 2001 04:54 PM
bambuski
Nov 12, 2001 10:35 PM
silvervtec01
Nov 4, 2001 06:56 PM
WeRkX
Nov 1, 2001 10:33 PM
