Replaced all mounts, vibration lingers
Old Jan 25, 2013
masterguns's Avatar
masterguns is an unknown quantity at this point
About 3 months ago, had struts and timing belt replaced at a local shop. Mechanic destroyed the left motor mount in the process and replaced it (at my expense, of course). Anyways, needless to say after getting my car back, it vibrated like a ****. I finally got around to replacing the front mount and right transmission mount last weekend. And the rear firewall mount just today. Upon tightening the last bolt, letting the car down, and patting myself on the back for a job well done, I took her for a test drive. While there is definitely an improvement, there is still a vibration that seems to be coming from the left hydraulic mount the shop supposedly replaced. Could that mount have been installed wrong or simply be a shotty part? Do I need to loosen and reset it you think?
Old Jan 25, 2013
Re: Replaced all mounts, vibration lingers
You can try "neutralizing" the mounts, it might help.
Google neutralizing motor mounts
http://tl.acurazine.com/forums/showthread.php?t=624485 (go to post #20)
Still bad? Replace the aftermarket mounts with factory parts.
mrohitredd
18
May 14, 2015 07:35 PM
bsmiley
Apr 27, 2015 01:27 PM
GH04si
Apr 15, 2015 08:13 PM
streetglower123
Apr 12, 2015 10:56 AM
thesushiboy
Apr 12, 2015 02:54 AM
