dd suspension help for 05 ex coupe
Old Dec 29, 2012
boxinggsxr's Avatar
boxinggsxr is an unknown quantity at this point
i need a suspension set up for my wifes civic right now it has some really cheap ebay ones and im not looking to slam it or anything. SO i've read some posts about rsx suspension bolting right up and that it drops it 1" but i've also read that theres issues with it. i've looked for a good oem one but nope most have alot of miles so what options can you guys advise?
Old Dec 29, 2012
boxinggsxr's Avatar
Re: dd suspension help for 05 ex coupe
just to put this out there we plan on having it for about 3-5 years at most and so the pro c's and konis are out the question its just going to be used to drive to work 10 miles a day and maybe a highway trip so i dont need a race suspension i'll save that for both of mine
Old Dec 29, 2012
Pheet's Avatar
Pheet is on a distinguished road
Tokico Blues and H&R springs for a comfortable 1.3(I believe) inch drop.
Old Dec 29, 2012
sl33pyriceboi's Avatar
the RSX suspension has higher spring rates and is accomidated for a heavier car. so it wont drop.
you best bet is to use tokico blues and some sort of lowering spring with a lower spring rate like H&R or some eibach prokits... the softest/most comfortable springs you will find are the TEIN H.techs. they are made specifically to ride smooth like a luxury vehicle while still dropping you about 1" all round.
Old Dec 29, 2012
boxinggsxr's Avatar
but with the rsx suspension rates being higher it will ride like a luxury car wouldnt it? and where did you find the htech i only found stechs? so then theres basically no suspension set up for about 4-500 bucks then?
Old Dec 29, 2012
Kennykid2002's Avatar
Kenny the Ricer
Spring rates higher = harder, stiffer ride.
You can find H.Techs just as easily as S.Techs
http://www.autoanything.com/suspensi...wering-springs
(With 15% off code, $153 shipped to your door)
With that little of a drop, you shouldn't absolutely need to replace shocks.
But it is recommended.
Old Dec 30, 2012
IF the rates are adequate to car weight and shocks are well matched to control the spring rates, you might be able to obtain close to that, but prolly you will need to have custom coils made, maybe from eibach and prior to hat to calculate rates depending on shocks/car weight/dynamics, etc, etc. It can be approached, tho but a lot of work required.
most end with stiffer ride on commonly available shelf parts.
Old Jan 3, 2013
boxinggsxr's Avatar
i def need new shocks thats why i wasnt too sure if i should go with t. blues with the htech springs or s2 springs>? which do you think will work better for daily driving...
so i dont get the whole stiffer ride cuz i cant really notice that much of a difference with my function form on my ek just that it hits bumps alot smoother instead of bouncing around...so is that the stiffer ride your talking about?
Old Jan 3, 2013
boldened above says your shocks were dead when you changed to FF
Strycker
Aug 2, 2015 08:40 PM
JKWood
Jul 28, 2015 03:45 PM
17
Jul 23, 2015 11:48 PM
Nalmonte
Jul 22, 2015 09:08 AM
breanna_17
Jul 21, 2015 04:01 PM
