07 Alternator needs replacement
Old Dec 28, 2012
SoCalSuzi's Avatar
SoCalSuzi is an unknown quantity at this point
So after spending $600 on a new engine mount, I now have a dead alternator.
Has anyone with an 07 Civic had to replace their alternator yet?
Does anyone have instructions or videos on a DIY replacement. I have changed the alternator in a 1980s Ford before, so I am tempted to try this one myself.
Any thoughts/suggestions??
Thanks!!
Old Dec 28, 2012
Re: 07 Alternator needs replacement
Coincidence? Maybe...maybe not.
I'm guessing you have somewhere between 60-100k miles. The alternators have been lasting much longer than that here.
Are you positive the alternator itself is the problem, not a blown fuse somewhere?
Maybe wires simply disconnected? Ground wire left off of the mount bracket?
Belt came off?
You are gonna be pizzed if you get it changed and it still doesn't work.
Dash fuse box, fuse #3, 10A.
100 amp fuse in the engine compartment box. (Car would probably appear completely dead if this is blown.)
Alt replacement is straightforward. Tight, but straightforward. The belt and 2 bolts. And the wires and little brackets.
Another thing: You paid $600 for one motor mount?
(The right side engine mount is the one that commonly goes bad. $180ish list. Mail order $126. Labor- about 1-1.5 hours.)
Someone else did it for that price of $600, I assume?
mrohitredd
18
May 14, 2015 07:35 PM
smmahan
Apr 15, 2015 08:17 PM
thesushiboy
Apr 12, 2015 02:54 AM
Cross
Bolt-on Engine Performance
Apr 3, 2002 03:00 PM
OPGForce
Feb 7, 2002 09:43 AM
