Overheating
Old Dec 28, 2012
sean2012's Avatar
sean2012 is an unknown quantity at this point
Overheating
Hello. I recently had some heating issues with my 2004 civic lx so I replaced the thermostat which seemed to fix the problem. A couple weeks later my car overheated so I replaced the radiator cap. Didn't fix the problem. So I have flushed the system, replaced the thermostat, and replaced the radiator cap. The next thing I can think of is the water pump. I don't see any leaks from the pump. Is there any specific spots I should check for leaking? Also is there anything else I should check instead of the water pump? I'd rather not have to drop $700 to replace it if its not the problem. Thanks
Old Dec 28, 2012
clinton_hedrick's Avatar
clinton_hedrick is an unknown quantity at this point
Re: Overheating
Sadly enough, most likely a head gasket. Are you losing any coolant?
Old Dec 28, 2012
Re: Overheating
This.
Plus possible damage to the head casting from overheating.
And it doesn't really HAVE to lose coolant, it could just push it out to the reservoir.
Old Dec 28, 2012
Re: Overheating
Originally Posted by ezone
This.
Right, it doesn't have to lose coolant, that just helps confirm a blown hg
Old Dec 28, 2012
sean2012's Avatar
Re: Overheating
This.
Well I didn't see any coolant leaking and yeah I do not know about the casting. I just dropped it off at Honda. Hopefully they can figure something out. Thanks for the responses.
Old Dec 28, 2012
sean2012's Avatar
Re: Overheating
Yeah turned out to be a leaky head gasket :/ $2300 bummer.
Old Dec 28, 2012
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Re: Overheating
Wow, that is a bummer. That's seems kind of pricey for just an HG job. Are you having other work done as well?
Old Dec 28, 2012
sean2012's Avatar
Re: Overheating
Yeah they are going to basically rebuild the top end. I'm at 150k miles and figured it'd be cheaper to just get it all done now. So they are replacing the water pump, valve adjustments and all that good stuff.
Update: so I have a question. The coolant was leaking into cylinder 2. How much damage to the cylinder or bottom half would that cause? It's been doing it for maybe a month or two I believe. It may have not been doing it every time but its been doing it for a while.
Old Dec 28, 2012
Matt_75's Avatar
Re: Overheating
I wouldn't think a whole of damage occurred or any at all unless some got past the rings and into the oil. Coolant in the oil can tear up all kinds of stuff. The coating where's off the HG at the firing ring area and causes the leaks mostly between coolant ports and the cylinder.
I just did my HG a of couple months ago. It was leaking into cylinder #3. I didn't see any evidence of coolant in the oil. So I just took everything apart cleaned everything up, put a new head, intake and exhaust gasket on. I had done the timing belt and water pump a year earlier so I didn't bother replacing them. I adjusted the valves. I changed the oil and filter twice just to be safe. I did a compression test and I had 210 psi across all four cylinders and she's been running like a top ever since.
Old Dec 28, 2012
Re: Overheating
Did you ever start the engine and have it misfire for a little while before clearing out and running ok again?
If no, then it probably wasn't putting coolant into a cylinder.
The most common head gasket breach is pushing combustion pressure into the cooling system.
It does not have to leak in both directions.
Old Dec 28, 2012
sean2012's Avatar
Re: Overheating
Okay I didn't see any coolant in the oil or it didnt appear to be any coolant in the oil. So hopefully it's okay.
And ezone it did start up with a misfire every once in a while and I could never figure out why but I know now.
Old Dec 28, 2012
Re: Overheating
Ok, so it probably was getting the spark plug wet with antifreeze...maybe after it sat overnight?
Probably won't be any big deal, most live just fine after the head gasket job.
The ones that usually have problems are the ones that were guzzling coolant through a cylinder, and the ones that overheated badly.
Billowing clouds of steam from the tailpipe that are visible for a mile, and traffic behind you can't see at all. THAT'S guzzling.
Upon teardown, if the cylinder in question looks like it just got steam cleaned, that might indicate guzzling coolant.
I doubt yours was anywhere near that bad.
Old Dec 28, 2012
sean2012's Avatar
Re: Overheating
Awesome well that makes me feel better about the situation! I'll post back here the results. Thanks for all the information.
Old Dec 29, 2012
04 Honda Civic's Avatar
Re: Overheating
Exactly what happened to my car. It would misfire only on overnight cold start, it was coolant in the cylinder.
One head gasket and almost 80k miles later and its still ok.
Old Jan 2, 2013
sean2012's Avatar
Re: Overheating
So Honda gave me a call today and said that the exhaust manifold was cracked. I would have never noticed it because it was always covered by the heat shield, but he asked if I ever heard any ticking and I said yes and he said that was probably the reason. Do you think the manifold was really cracked? or is he squeezing some more money out of me and would that be the cause of the ticking? The car has 150k miles.
Old Jan 3, 2013
Matt_75's Avatar
Re: Overheating
It's very possible it was cracked. A ticking sound in the exhaust area, AFAIK, can be attributed to a cracked manifold.
If you're that concerned about it, I would have them show you the crack. It's been mentioned about welding cracks here, but IMHO, I'd replace it. Just personal preference.
Old Jan 3, 2013
Re: Overheating
They aren't lying.
Old Jan 3, 2013
Re: Overheating
Cracked manifold?
I thought the car was overheating, I guess you have two problems?
Old Jan 3, 2013
sean2012's Avatar
Re: Overheating
Okay yeah I had them replace it. Thanks
Got the car back today and so fad everything is running smoothly!
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
solarpunk70
Apr 12, 2016 11:43 AM
raymondxcho
Sep 29, 2015 09:00 PM
hondalx2002
18
Sep 15, 2015 10:54 PM
tooly145
Sep 5, 2015 01:05 AM
