Turn Signals Not Working Properly
Old Nov 17, 2012
Single73's Avatar
Single73 is an unknown quantity at this point
I have a 2002 Honda Civic.
When I try to use my turn signals sometimes I get one or two blinks out of them but more often than not they don't work at all. It is the same for both the right and left. I checked the fuses and they are fine. I was going to replace the turn signal relay but am having a lot of trouble getting it out.
Does it sound like the turn signal relay could or would be the problem?
Any tips on how to get it out?
What else might it be?
Thanks.
Old Nov 18, 2012
Re: Turn Signals Not Working Properly
Thanks.
Pliers?
I would be testing instead of guessing....But yeah, sounds like the flasher relay.
Old Nov 19, 2012
Single73's Avatar
Originally Posted by ezone
Pliers?
Thanks. I need to get it out to test it, no?
Also forgot to mention that I have the same problem with my hazards.
Old Nov 19, 2012
The flasher relay has its own control unit built in so you can't really test it like a normal plain relay.
I would have pulled it out to test everything else from that socket.
A wiring diagram leads the way for me.
Hazards and turn signals all use the same parts.
Old Nov 19, 2012
CraigW's Avatar
Those things are incredible TIGHT fitting.
Old Nov 27, 2012
Single73's Avatar
Managed to get it out with a screwdriver and pliers. Also had to contortion myself to get at it.
Turns out it was the relay. I gotta to say the people at Auto Zone were not as helpful or knowledgeable as I hoped or expected. It took them forever to match it up. Then when it didn't look exactly the same they seemed dumbfounded. The replacement was longer than the original. I was worried it wouldn't fit. At least they were willing to take it back if it didn't work. Fortunately it did.
Old Nov 27, 2012
"Would you like fries with that?"
Old Nov 28, 2012
CraigW's Avatar
Thanks for the update on the fix.
Old Dec 2, 2012
dawedore's Avatar
dawedore is an unknown quantity at this point
Great start of business I appreciate it please care of it as a guide but in other words it has great information about the topic in which it has fully confidence…
Las vegas credit repair
Credit repair las vegas
shaejb15
Apr 26, 2015 07:44 PM
Fastfebur
Apr 22, 2015 01:37 PM
blackbullet
Dec 1, 2001 03:44 PM
civicPRODIGY
Nov 12, 2001 09:32 PM
GhettoCivic
Nov 12, 2001 03:15 PM
