Dimming headlights....not alternator??
Old Oct 27, 2012
03-GoGo-coupe's Avatar
03-GoGo-coupe is an unknown quantity at this point
Unhappy Dimming headlights....not alternator??
Ok so I recently had the alternator checked in my 03 lx coupe because at random times and in no certain situation, the lights will quickly dim and return to normal. This is done in a sort of pattern of dim dim dim normal...dim dim normal but not as if there is a draw on the alternator or anything. The honda dealership stated the alternator tested fine but mentioned something about "load dumping" that was supposed to be normal but I'm not sure I completely buy it. (and they never told me what voltage was measured during testing) The interior lights are unaffected when this happens and there's no amps or any stereo equipment in it. I couldn't find a thread about this type of thing so any info or a link to a thread would be greatly appreciated!
Old Oct 27, 2012
Re: Dimming headlights....not alternator??
Maybe it is normal. Charging is reduced during some low-load periods of time.....
http://hondaswap.com/ecus-electronic...s-work-524380/
Old Oct 28, 2012
yup, charging goes from around 12v to around 14v all the time while driving. that 2v difference means hundreds of lumens less light from the headlights, since voltage and lumen output is exponential. it is normal and part of a gas saving feature to reduce or stop alternator charge voltage under certain conditions. also if the radiator fan is switching on and off, that can put a large load on the electrical system, which can cause dimming as well.
Old Oct 28, 2012
So replacing the alternator wouldn't remedy this I'm guessing. It's just weird.
Old Oct 28, 2012
Thumbs up Re: Dimming headlights....not alternator??
Thanks for the info.
Old Oct 28, 2012
no, but you could bypass the ELD (electrical load detector) so the alt is at full output all the time. it may cause unwanted side effects like worse mpg, shorter alt life, and possibly battery overcharge.
Old Oct 28, 2012
Air conditioner cycling on and off, same thing.
Nope. It's a feature.
It's just weird.
Not weird, it's just not like every other car manufacturer everyone is used to.
It's a Honda thing and has been for decades.
Here is another article to read, first item on the first page: http://dvpatel.homelinux.com/forumfiles/SN/A001200.pdf
HTH
Old Oct 28, 2012
UPDATE! This morning when I went to leave for work the same dimming was happening only this time the idle was also affected and the battery light was flickering on the dash. Had the alternator check AGAIN and it in fact was the problem. It was over charging so we replaced it and it does not do any of the things it did that were supposedly "normal". This isn't me snubbing my nose to any of you, I just can't see anything normal about what my car was doing.
Old Oct 28, 2012
UPDATE! It was over charging so we replaced it and it does not do any of the things it did that were supposedly "normal". This isn't me snubbing my nose to any of you, I just can't see anything normal about what my car was doing.
Keep in mind that nobody here can actually SEE what your car is doing, we can only go by your descriptions.
I may have come up with something completely different if I could see it firsthand.
You mentioned the "load dumping" so I kinda ran with that.
Good you got it fixed though.
Old Oct 28, 2012
I totally appreciate all the info given here and I don't want to come off as ungrateful at all. My description may have been insufficient but what you guys were saying was the same thing the adviser at the honda dealership was saying so I was prepared to accept it as just one of those things. Just happens that what may have appeared normal to the tech that tested it just happened to be a symptom of failure. I'm glad it's fixed now I just have to prepare to have my transmission fixed soon....sigh! If it ain't one thing it's another I guess!
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Bonobo
Oct 2, 2015 06:58 PM
ken4444
Sep 30, 2015 07:37 PM
260000milesgoal
Sep 25, 2015 07:41 PM
IronFist
Sep 25, 2015 07:13 PM
