3rd Brake Light Problem
Old Oct 25, 2012
SSMCivicCoupe's Avatar
SSMCivicCoupe will become famous soon enough
So I recently removed the stock spoiler on my car becuase I think our cars look way better without the spoiler, but here in California we need to have a 3rd brake light and I wanted to know since I removed my spoiler which had the brake light on it, Is there a way where I can install a 3rd brake light somewhere?
Old Oct 25, 2012
sl33pyriceboi's Avatar
Re: 3rd Brake Light Problem
you have a stock 3rd brake light on the bottom of your rear window. its prob unplugged.
Old Oct 25, 2012
CraigW's Avatar
8th gens that have the external 3rd light have a rear deck that has no 3rd light integrated into it.
Old Oct 25, 2012
dubtee1480's Avatar
Please, DubTee is my father, call me Dub
dubtee1480 is an unknown quantity at this point
Bottom of the rear window will be the place to go, if like sl33py said you don't already have one there. You can buy LED strips online or if you want something that looks more OEM you could probably use the third brake light off of a 2003-2005 Honda Accord, the model with the elongated horizontal tails; they integrated it into the trunk deck when they went to triangular tail lights. The angle of the rear window might not be exact but should be pretty close. When I had the windows tinted on my wife's Accord the installer mentioned removing the brake light and tinting between it and the window so you should be able remove one off of a junker and drill holes in the rear shelf of your car and mount it there. A local professional auto paint should be able to help you match a spray can of SEM interior paint to paint it to match.
Old Oct 25, 2012
Good thing he's got a 7th gen
Old Oct 25, 2012
CraigW's Avatar
I have seen 7th gen factory SE models that black out the back window at the brake light area. (same black they use around perimeter of glass)
Old Oct 25, 2012
Yea this is how mine is rite now. So even if I do put a third brake light from another car the light will not go through because of it being blacked out in that area. Would it be possible to put a Red LED strip right above that area or something similar to OEM?
Old Oct 25, 2012
dubtee1480's Avatar
If you want to mount something on the outside of your trunk deck, something from here might work: http://www.watsons-streetworks.com/l...ke_lights.html
They have some billet framed lights that could be mounted on the back of your car.
There are some here that are designed to mount inside the window with no gap between the light source and the window: http://www.ronfrancis.com/products.asp?dept=25
I've never dealt with either of those vendors, just what I found on a quick google search.
Old Oct 25, 2012
Which wires are for the Brake lights that I could tap into for the third brake light?
Old Oct 26, 2012
CraigW's Avatar
Those would be WHT/BLK and BLK.
Old Oct 27, 2012
So I'm assuming the white/black is the power? And the black is the ground?
Old Oct 28, 2012
CraigW's Avatar
^^^ correct.
What about the wiring that went to the original 3rd light you removed ? Tap into it.
Old Nov 2, 2012
^^^ correct.
Yea I just tapped into the old wiring. Finished installing it last night and it doesnt look bad. Thanks for all the help guys. One less thing I have to worry about getting pulled over for.
Xuhme
21
Aug 7, 2023 03:40 PM
Poopies
Apr 20, 2017 11:36 PM
SSMatey
Apr 13, 2015 06:09 PM
