No beeping on door lock
Old Oct 25, 2012
seahorse12's Avatar
seahorse12 is an unknown quantity at this point
Hi,
I just got some bodywork done on the front end of my car (bumper, hood, grill replaced)...minor wreck but wanted to get it all fixed up nice.
Anyways, looks like now my door alarm wont beep no more. It works. I can lock it with the button on the key but no sound when I press it twice. Can it have anything to do with the body work done on the car? They did replace the hood and the latch for the hood
Any ideas?
Thank you.
Old Oct 25, 2012
mikey1's Avatar
Re: No beeping on door lock
you mean the horn beep?
does the horn work when you press it on the steering wheel?
if not, maybe the horn itself is damaged or the wiring to it
Old Oct 26, 2012
seahorse12's Avatar
No not the horn. The small sound that you get when u press the door lock twice. The one that tells you that the doors are locked...that sound Im talking about
Old Oct 26, 2012
CraigW's Avatar
That sound IS from the horn.
Do you have factory alarm ? Does it arm when locking ?
Do the parking/tail/licence lights flash when locking ?
And yes, double check the horns operation.
Old Oct 26, 2012
mikey1's Avatar
that sound DOES come from your horn!
press the horn on your steering wheel, does it work? my guess is no
Old Oct 28, 2012
seahorse12's Avatar
You are right...the horn doesnt work as well...Sorry didnt notice before....brake lights are fine. I think even the mechanic did not notice the horn...So is this an easy enough fix that I can do? I would like to fix it myself...Can you guys direct me as to what should i be checking for other than the fuse boxes
Old Oct 28, 2012
dubtee1480's Avatar
Please, DubTee is my father, call me Dub
dubtee1480 is an unknown quantity at this point
this
Old Oct 29, 2012
CraigW's Avatar
With engine off and at quiet location...listen for a clicking noise when attempting to blow the horn. (horn relay)
Old Oct 29, 2012
mikey1's Avatar
if you have a voltmeter you can unplug the wiring to the horn, check the voltage there while another person is pushing the horn on the steering wheel,
when they push the horn the voltage should jump up to 12+ volts (whatever your battery voltage is),
if this test turns out positive, then your horn itself is defective, probably happened in the accident and nobody noticed,
if the test is negative, check for a blown fuse or faulty wiring,
could also be the horn switch itself on the steering wheel, however that is alot less likely,
Old Nov 5, 2012
seahorse12's Avatar
Thank you for the response....
So i checked and noticed that the horn itself was damaged. Replaced it and works fine. Now just yesterday, ac stopped working. Fan is blowing air but not cold. If i turn to heat i get warm air (I really think it was working even after the accident, till like last wk..though now Im having seconds thoughts about pretty much everything). Checked freon level and looks like okay...actually looks like a lot on the low line...but i didnt fill it or change it....
After the crash, radiator and condensor were a little bent but they were working so i didnt replace them....but now something has happened....
I dont hear no click sound when i turn the ac on, so looks like the compressor is not engaging??
Can someone please advise on what should i be checking? How can i know if compressor is okay....or what is wrong with ac??
Thanks a lot
Old Nov 5, 2012
This HAS to be a good story.
This should be an insurance and shop matter.
The job, apparently, is not finished.
Same with the horn, that was accident damage.
Old Nov 5, 2012
mikey1's Avatar
agreed,
this should all be taken care of under your insurance claim, that is what you are paying them for,....if they missed a damaged horn, that makes me wonder what else they might have missed,
take your car back to them and tell them you want your car to be repaired till its in the condition it was previously to the accident, thats what you are paying them for and that is their job!!!
Old Feb 24, 2017
Maharett's Avatar
Maharett is an unknown quantity at this point
I know this thread is dead but I'm hoping someone can help me here with this issue.
I have a 2002 Honda Civic Ex. Recently had the window regulator for the driver side window replaced and ever since then my car no longer beeps when I hit the lock remote twice. I suspect it's an issue within the door itself due to shotty workmanship from the mechanic. Also since then when I push the actual door lock button down manually it no longer locks all the doors. (As a side note ive also noticed that the mirror adjust button no longer allows me to shift the exterior mirror at all, not really 100% sure if this worked prior to the molestation of my car)
Factory alarm/locking system
Fuses have been checked
All door sensors have been cleaned
Horn does work when pushed
Click sound for sending the signal to the horn when the lock remote button is pushed twice can be heard
No hidden button under the steering wheel or near the hood latch
Tried the push and hold the lock button trick on the remote (no go)
Tried the hold lock and unlock button on the remote as well (same results)
Brought it back to the shady mechanic and after an hour or so of trouble shooting he gave up and insisted it's not supposed to beep.. Nor are the other locks supposed to engage when the driver side is manually pressed down weather or not the car is on.. I've had this car since 2005 and I love it dearly, I know what features it's has and hasn't had very well in that timeframe. Please I hope someone can help!
Old Feb 24, 2017
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
I was going to suggest you check to make sure all doors, hood (and trunk too I believe) are shut completely before trying again but you mention the power mirror not working too. This leads me to believe that the you may have a short in the wires to the driver's door (especially if you can only adjust the passenger mirror and NOT the driver's side). Area to inspect is the junction between driver's door and chassis under the rubber conduit. Peel it back and start testing.
Old Feb 24, 2017
Check fuses in booth fuse boxes....
Remove door panel.....figure out if Mr. Goodpliers left stuff unplugged or butchered wiring in the door.
There should be two connectors on the door latch, I'd wonder if at least one was left unplugged....or has damaged wires.....maybe got caught in a panel screw or something.
Draping the power mirror harness under the glass was a common mistake on some cars (can't remember if that applies to yours) and that would damage the harness when the glass was lowered. At any rate, you will be able to see the mirror wiring when you get the door panel off.
Old Feb 27, 2017
Maharett's Avatar
It's actually both mirrors that I can no longer adjust
And I checked and replaced both sets of fuses (just in case) still no luck. I think you are correct though and it's time to just take the door panel off and take a look at what exactly they touched.
I'm sure i'll have an update or more questions soon. Thanks for the tips!
The emotes/smilies it lets you add reminded me of something I heard someone say once I thought you'd get a kick out of it.
"Something's wrong my submarine light is on in my car.."
Old Apr 22, 2024
DPB's Avatar
DPB
DPB is an unknown quantity at this point
Re: No beeping on door lock...SOLVED! 1 of the 2 doorlock connectors was not fully in
My 2002 Honda Civic Si was hit on the driver's side and I had it repaired. The door panel is original the shell is from another 2002 Civic Si. The exterior mirrors work fine but the horn no longer beeps when the remote is pressed twice. The fuses under the hood have been checked and look fine, the horn works too. I see the previous info about the door sensors need to be cleaned. The remote does lock all my doors ( the side door is a bit slow to react if I am too far away) and the window goes up and down just fine.
What can I have the mechanic check to get that horn beep when remote locking? Panic button works fine but I really miss the locking beep ( makes it finding my car in crowded parking lots easier too).
I hope this thread still gets some activity! Thanks!
bradix
Electronics
Dec 14, 2020 08:28 AM
05es1guy
Electronics
Jul 2, 2019 09:47 AM
Sweetnsauer
Sep 7, 2017 02:56 PM
brutie
Jul 19, 2011 06:47 AM
Yoshiemaster
Dec 27, 2005 09:49 AM
