2001 -up civic/2002 RSX shortened struts
Old May 4, 2002
strutwizard's Avatar
strutwizard is an unknown quantity at this point
[IMG]i/expressions/face-icon-small-smile.gif[/IMG]Featuring shortened body for smoother ride over using just lowering springs, shortened piston to maintain proper spring compression to control ride quality and improve overall handling.
Range of drop front and rear from 1 1/2 to 3 1/2 depending on lowering spring used.
Two part automotive painting process used on strut components.
Zinc plated thread built on strut body for use with adjusting nut used to raise and lower the car.
Adjusting wrench supplied with complete installation instruction
Factory bolt on application, no modification required like other struts on the market.
Uses standard lowering springs on the market or Modified Bec-tech's for extreme lowering.
Price for a set of two front struts, and two rear struts is 599.00 plus shipping charges.
Bec-Tech lowering springs price for a set of 4 is 150.00.
Any question email me
thanks, for your time
Old May 4, 2002
TOOLOWCIVIC's Avatar
These struts would they fit an 01 civic?
Old May 4, 2002
Decamo's Avatar
Decamo has a little shameless behaviour in the past
Have any pics? Who makes these?
Old May 4, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
GRRRRRRRRR.......I KNEW I SHOULD HAVE WAITED FOR THEM!!!!!!!!! DAMNIT!
Old May 4, 2002
Yes, they will fit the 2001 civic direct bolt in.
thanks
I make them, I designed them and manufacture them in Ontario,Ca
Company is Bec-Tech Design
Old May 4, 2002
Email address is tobuybectecs@cs.com
thanks, again
Old May 4, 2002
I will have final pictures next week for everyone viewing. Steven has the first set on his car that were not painted with the two paint process for r & d purposes.
Old May 4, 2002
Are these struts better than KOnis. Will it ride like stock at a lower height?
Old May 4, 2002
mwwhonda's Avatar
i belive that they are a modified stock damper.....so in turn, would provide improved ride quality with a lowering spring [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old May 5, 2002
Decamo's Avatar
Thats pretty interesting. Please provide pics on a 2001 civic. Is it rebuidable? Why don't ppl make rebuildable shocks with different shock fluids? Like R/C cars.
Old May 5, 2002
lowonair's Avatar
lowonair is an unknown quantity at this point
how much just for the front? how much shorter is the body from the stock units
Old May 5, 2002
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
wait...if u just use the stock RSX shocks and without changing the valve then $600 is too much
Old May 5, 2002
B390LU's Avatar
B390LU is an unknown quantity at this point
<< Zinc plated thread built on strut body for use with adjusting nut used to raise and lower the car. >>
I already have H&R lowering springs now so that does mean I can lower the car more with your struts?A very tempting offer if it's height adjustable as what I have in mind.Pls provide more info,thx.
Old May 5, 2002
The case is shortened from 1 to 2 inches, it depends on what the customer needs for a specific use.
Yes, the oil can be changed to different types of oils, but they would need to be return for this type of work because
most people don't have the required equipment in their garage.
Yes, you can lower the car more with the struts when used in combo with lowering springs.
Cost on two fronts would be $400.00
Old May 5, 2002
WhosYoDadday85's Avatar
www.ImportFactor.Com
WhosYoDadday85 should not be trustedWhosYoDadday85 should not be trusted
So if I understand correctly, these are some struts?
If they are struts, do you guys have coilovers too? Or do you have like some kind of full coilover system going (maybe that's what this is......[IMG]i/expressions/face-icon-small-confused.gif[/IMG] )...clue me in
Old May 5, 2002
B390LU's Avatar
Ok so my H&R drops the car about 1.5".How much lower can I go with the struts?The front set is $400 how about the rear ($599-$400=$199)?Thx
Old May 5, 2002
Yes, they are just like real coilovers, built on thread over the strut body with adjusting nut to raise and lower the car.
The height from 1 1/2 drop would be another 1 to 1 1/2 with the shortened ride height adjustable struts.
Yes the price for a complete set is 599.00
Old May 5, 2002
mohawkboom's Avatar
Hey Strut Wizard,,,I'm from Montreal.. Need a guinnea pig sedan to work on [IMG]i/expressions/face-icon-small-smile.gif[/IMG].. and price is $599US What about $CAD?
Old May 5, 2002
Same price US and Cad. 599.00 plus shipping
Old May 5, 2002
mohawkboom's Avatar
$599 Canadian dollars.. or $599 US dollars??
Old May 5, 2002
Decamo's Avatar
If these struts lower the car by lowering the spring mounts doesn't that 'cause the spring rate to be way too soft at lowered height? What prevents it from bottoming out and riding on the bump stops?
Old May 5, 2002
RobearRacing's Avatar
RobearRacing is an unknown quantity at this point
Strutwizard...PLEASE CALL ME!!!!
You know who I am..we need to talk man..
Rob
Old May 5, 2002
Hey Rob, are you going to sell them? IF so how much? Do you think they are better than KOnis?
Old May 5, 2002
Hey Strutwizard how much for the rear only and what kind of warranty do they have? Will they work with the ground control coilovers I already have? Do you have a website. How do I order them and will you accept Visa.
Old May 5, 2002
TOOLOWCIVIC: E--mail me.
Old May 5, 2002
I sent you an email.
Old May 5, 2002
Do to the fact that the strut are shortened and the piston also, the spring maintains the required compression to work like the factory set up as far as bottoming out on the bump stops.
Old May 5, 2002
Its not required to use the ground control set up because the struts already have the adjusting sleeve and nut on them.
thanks
Old May 5, 2002
Sorry 599.00 U.S. I know the customs kills when receiving from the U.S.
Old May 5, 2002
The outside of the body is factory, but the internals are not the same when I finish with them. Disc changes and different types of oils are used.
