2001 Automatic Honda Civic won't start
Old Sep 11, 2012
jmorales2147's Avatar
jmorales2147 is an unknown quantity at this point
So my 2001 Honda civic won't start, crank, or turn over at all. Took the car to get checked out. Mechanic told me the starter went bad and there was a short under the dashboard. Replaced the starter but it still won't start, crank, turn over, etc. Can't find were the short is. The rest of the electrical works spark plugs were changed about three weeks ago and the battery tested out fine. Any Ideas?????
Old Sep 11, 2012
GolNat's Avatar
Prelude Owner
Re: 2001 Automatic Honda Civic won't start
Ignition key cylinder maybe, or bypass module. Different mechanic might work.
These are always helpful:
Old Sep 11, 2012
Alright I'll check that stuff out and try to find a new mechanic.
Old Sep 11, 2012
CraigW's Avatar
What about the cluster lights when key 1st turned to II ?? On ? Dim ?
Anyone inspect the battery terminals/large gauge wire connections as a culprit ?
A short will blow fuses... you may have an open though.
And yes, get someone else to diagnose, otherwise the parts cannon may make another appearance.
Old Sep 13, 2012
04 Honda Civic's Avatar
If this is over your head, then get a new mechanic. Electrical issues can be tricky especially when it comes to shorts/opens.
Start with the basics.
Check:
-Battery Voltage
-Fuses
-Grounds
LionSpratt
Jan 29, 2017 11:07 PM
jessicakaybby
Apr 20, 2015 12:11 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
