Is there a problem with the exhaust manifold warping?
Old Sep 10, 2012
Biscuit's Avatar
2001 Civic LX Sedan
Biscuit will become famous soon enoughBiscuit will become famous soon enough
After dealing with a bad cam sensor and driving the car two times in limp mode there is an exhaust leak where the manifold meets the head. I replaced that gasket and the lower gasket and I still have the leak.
Has anyone else had this problem?
Old Sep 12, 2012
lazlong's Avatar
Re: Is there a problem with the exhaust manifold warping?
Sounds like you may have warped the head. You'll need a precision straight edge and feeler gauges to check.
Old Sep 13, 2012
Biscuit's Avatar
2001 Civic LX Sedan
Based on what I hear when I slightly rev the engine I believe there is a crack in the manifold. I will have to remove the manifold to confirm this theory.
If it is only a crack I can stop-drill the crack and weld it shut. I hope the problem is that easy.
Poopies
Apr 20, 2017 11:36 PM
Supramk3
May 11, 2015 07:55 PM
Civic4ever1996
Apr 16, 2015 08:30 PM
AEMcivic
Dec 5, 2001 04:02 PM
MY01HX
Nov 12, 2001 04:25 PM
