Strut hitting hood? pics inside...help needed
Hey everyone,
I've been hanging around here for a while...not really posting...but taking advice from everyone on their cars. Now I have an issue that I really need help with. In the last 6 months I have replaced my struts with tokico d-spec struts on all 4 corners along with eibach pro-kit springs. Since that time there has been an unexplained rattling coming from my passenger side strut area. I have been looking and looking and haven't been able to figure out what it is. Well it was staring me right in the freaking face. The strut is actually hitting my hood!! In the pics below, there is a huge indentation where the strut has been slamming into my hood. I was wondering if anyone who has d-specs has had this issue?? Can anyone recommend how i should take care of this? Is this a strut issue or should I be ok just cutting a hole in the support bar? Also, the passenger side strut is leaning in to the right. THe mount is brand new and this has just been slowly getting worse. If anyone wants to shoot some ideas my way...it would be much appreciated. Thanks everyone.
Re: Strut hitting hood? pics inside...help needed
well...unfortunately it is hitting on both sides, however the driver side is less severe than the passenger side. The driver side strut is not leaning, however. This is really frustrating and I feel slightly stupid for not figuring this out sooner. What are the odds that both struts are bad? The ride feels normal to me. They don't seem blown at all or anything like that. Could the control arm be bent causing the lean? That still doesn't explain the hood banging though.
further thoughts on this issue?? Not trying to be a pain...I'm just trying to get this resolved ASAP before I start my new job next week. I really appreciate all the help guys!
those look pretty sweet man...i might have to give those a shot, but it still doesn't solve the bigger issue which is my strut leaning. I'm thinking something is obviously bent...but what?? lol. Maybe an upper control arm?
lol yeah i figured it would...but an00bis make my damn strut stop leaning!!!!!! NOW!! lol...jk man...no but really...I need someone to tell me how to fix this..haha. I've replaced everything in my front suspension except for upper CA's and ball joints. This is the weirdest thing ever.
Ill agree with low life.. you have a bigger problem. Call the company see if they have any ideas. I havent messed with aftemarket stuff very much. But those studs on the strut look crazy long..
I'm surprised nobody has mentioned an obvious solution yet...
Drill a large clearance hole at the point of contact in your hood so the top of the strut just passes through. That is, as long as you don't mind this sort of DIY that requires a bit of hacking away. I'd give you the green light, seeing as there is a hefty flange there to cut away and there's already plenty of stock holes in there for other reasons. As long as you're careful and clean, that should at least help you forget about the annoying problem for good. I'd also put some thick foam pads under the hood just in case, that way if your struts are still hitting, they won't put dents in your hood.
Just make sure you didn't get defective struts in case something might be wrong with the way they were manufactured.
I was gonna go with the whole cutting a hole in the hood bracing....but that still won 't fix the issue of the leaning strut tower...unless it was this obstruction that caused the leaning to begin with?? I think the leaning is the bigger issue now as the other is an easy fix. I guess I could disassemble my suspension and figure out whats wrong
The issue I'm having with the leaning strut seems really bizarre. I'd be interested to know if anyone on this sit =e has ever had a similar issue. Seem's pretty rare to me though.
Well....Seeing as how I own the car and to my knowledge no one has installed camber plates behind my back in the last 2 months, this was definitely not on purpose! lol
Alright Guys. The issue is getting a little worse. The strut is leaning pretty hard core to the inside and I'm really worried something is bent. Could the strut mount be bad??
Any other thoughts would be really really helpful.
Agreed, pull it out and inspect it thoroughly, then put it back.
If you can't find the problem, I think it's time to turn to the professionals. Have your car looked at by a suspension shop or even a Honda dealer if they still support your car after that modification. And again, if it's a faulty shock, call up the company right away to get a refund.
I'm also going with the idea to remove them and check things out...double check all of the suspension compnents under there and make sure nothing is missing, loose, or bent.
other people have gotten Tokico D-specs on the forum and i haven't heard of anyone having the issues i'm having. I thought I could've had the wrong struts too but I know that the paperwork was for the correct ones...which probably doesn 't mean ****! GRRR....I just want my suspension to be set...this stuff is frustrating.
Can you take a picture of the leaning strut? Then take a picture of what the camber looks like with the wheel on... I want to see a picture of the wheel itself.
If they are the right struts, it's definitely an install error. D specs don't hit the hood when done properly. You need to thoroughly inspect your suspension to see why the passenger side is leaning. Like above, start taking stuff apart until you discover a mistake or problem.
Freaking Awesome! Well, I'm working a ton this weekend but next week I will have time to tear into it. Actually, Sunday Might work. I'm gonnna take a picture of the wheel camber and out it up here in the next day or two and then Sunday I will take the struts out. I sorta feel like an idiot. I should've figured they were the wrong struts waaaaaay before now. Oh well, live and learn I guess. Hopefully I can fix things relatively soon. Thanks for all the help guys. I will keep you updated.
