Strut hitting hood? pics inside...help needed
Old Jul 14, 2012
tdawg50's Avatar
tdawg50 is an unknown quantity at this point
Hey everyone,
I've been hanging around here for a while...not really posting...but taking advice from everyone on their cars. Now I have an issue that I really need help with. In the last 6 months I have replaced my struts with tokico d-spec struts on all 4 corners along with eibach pro-kit springs. Since that time there has been an unexplained rattling coming from my passenger side strut area. I have been looking and looking and haven't been able to figure out what it is. Well it was staring me right in the freaking face. The strut is actually hitting my hood!! In the pics below, there is a huge indentation where the strut has been slamming into my hood. I was wondering if anyone who has d-specs has had this issue?? Can anyone recommend how i should take care of this? Is this a strut issue or should I be ok just cutting a hole in the support bar? Also, the passenger side strut is leaning in to the right. THe mount is brand new and this has just been slowly getting worse. If anyone wants to shoot some ideas my way...it would be much appreciated. Thanks everyone.
ID:	83691   Click image for larger version
ID:	83692   Click image for larger version
Old Jul 14, 2012
lazlong's Avatar
Re: Strut hitting hood? pics inside...help needed
If it's only the one side I'd say you probably got a bad strut out of the package.
Old Jul 14, 2012
tdawg50's Avatar
well...unfortunately it is hitting on both sides, however the driver side is less severe than the passenger side. The driver side strut is not leaning, however. This is really frustrating and I feel slightly stupid for not figuring this out sooner. What are the odds that both struts are bad? The ride feels normal to me. They don't seem blown at all or anything like that. Could the control arm be bent causing the lean? That still doesn't explain the hood banging though.
Old Jul 14, 2012
lowlife9's Avatar
were did you get those mounts from ?? did you install them in the rite direction.
Old Jul 14, 2012
tdawg50's Avatar
they are moog strut mounts from autopartswarehouse.com I believe. I am sure I installed them correctly
Old Jul 14, 2012
tdawg50's Avatar
further thoughts on this issue?? Not trying to be a pain...I'm just trying to get this resolved ASAP before I start my new job next week. I really appreciate all the help guys!
Old Jul 14, 2012
an00bis's Avatar
Registereded!!
an00bis is an unknown quantity at this point
im not sure if these would help but
http://passwordjdm.com/PasswordJDM-B...P8354C834.aspx
Old Jul 16, 2012
tdawg50's Avatar
those look pretty sweet man...i might have to give those a shot, but it still doesn't solve the bigger issue which is my strut leaning. I'm thinking something is obviously bent...but what?? lol. Maybe an upper control arm?
Old Jul 16, 2012
an00bis's Avatar
Registereded!!
****, beats me man haha
those should fix the hood part of the problem.
Old Jul 16, 2012
tdawg50's Avatar
lol yeah i figured it would...but an00bis make my damn strut stop leaning!!!!!! NOW!! lol...jk man...no but really...I need someone to tell me how to fix this..haha. I've replaced everything in my front suspension except for upper CA's and ball joints. This is the weirdest thing ever.
Old Jul 17, 2012
tdawg50's Avatar
let's get some more replies/suggestions up in here! Anybody???
Old Jul 17, 2012
lowlife9's Avatar
thats like a very ugly over priced band-aid. you can accomplish that with $2.00 dollars and a trip to the hardware store.
Old Jul 17, 2012
04 Honda Civic's Avatar
Ill agree with low life.. you have a bigger problem. Call the company see if they have any ideas. I havent messed with aftemarket stuff very much. But those studs on the strut look crazy long..
Old Jul 17, 2012
krudmuphin's Avatar
I'm surprised nobody has mentioned an obvious solution yet...
Drill a large clearance hole at the point of contact in your hood so the top of the strut just passes through. That is, as long as you don't mind this sort of DIY that requires a bit of hacking away. I'd give you the green light, seeing as there is a hefty flange there to cut away and there's already plenty of stock holes in there for other reasons. As long as you're careful and clean, that should at least help you forget about the annoying problem for good. I'd also put some thick foam pads under the hood just in case, that way if your struts are still hitting, they won't put dents in your hood.
Just make sure you didn't get defective struts in case something might be wrong with the way they were manufactured.
Old Jul 18, 2012
an00bis's Avatar
Registereded!!
you wont see those risers near my car, i just happen to run by them right before i saw this thread
Old Jul 18, 2012
tdawg50's Avatar
I was gonna go with the whole cutting a hole in the hood bracing....but that still won 't fix the issue of the leaning strut tower...unless it was this obstruction that caused the leaning to begin with?? I think the leaning is the bigger issue now as the other is an easy fix. I guess I could disassemble my suspension and figure out whats wrong
The issue I'm having with the leaning strut seems really bizarre. I'd be interested to know if anyone on this sit =e has ever had a similar issue. Seem's pretty rare to me though.
Old Jul 18, 2012
lowlife9's Avatar
ive never seen that before only time i see that much lean is when someone uses an adjustable camber plate and is on purpose.
Old Jul 19, 2012
tdawg50's Avatar
Well....Seeing as how I own the car and to my knowledge no one has installed camber plates behind my back in the last 2 months, this was definitely not on purpose! lol
Old Jul 24, 2012
tdawg50's Avatar
Alright Guys. The issue is getting a little worse. The strut is leaning pretty hard core to the inside and I'm really worried something is bent. Could the strut mount be bad??
Any other thoughts would be really really helpful.
Old Jul 25, 2012
TFMEX's Avatar
CO&CA
TFMEX is a jewel in the roughTFMEX is a jewel in the roughTFMEX is a jewel in the rough
Pull the damn thing out and look at it if you haven't already.... Its not normal... take a deeper dive.
Old Jul 25, 2012
krudmuphin's Avatar
Agreed, pull it out and inspect it thoroughly, then put it back.
If you can't find the problem, I think it's time to turn to the professionals. Have your car looked at by a suspension shop or even a Honda dealer if they still support your car after that modification. And again, if it's a faulty shock, call up the company right away to get a refund.
Old Jul 25, 2012
Aetoc's Avatar
Aetoc will become famous soon enoughAetoc will become famous soon enough
I'm also going with the idea to remove them and check things out...double check all of the suspension compnents under there and make sure nothing is missing, loose, or bent.
Old Jul 26, 2012
tdawg50's Avatar
damn...yeah I know I need to pull it. It sucks...I just had it all apart. this is a pretty recent issue.
Old Jul 26, 2012
BlueEM2's Avatar
Whachya lookin at?
I wonder if you got the wrong struts.
Old Jul 26, 2012
tdawg50's Avatar
other people have gotten Tokico D-specs on the forum and i haven't heard of anyone having the issues i'm having. I thought I could've had the wrong struts too but I know that the paperwork was for the correct ones...which probably doesn 't mean ****! GRRR....I just want my suspension to be set...this stuff is frustrating.
Old Jul 26, 2012
BlueEM2's Avatar
Whachya lookin at?
Can you take a picture of the leaning strut? Then take a picture of what the camber looks like with the wheel on... I want to see a picture of the wheel itself.
Old Jul 26, 2012
BlueEM2's Avatar
Whachya lookin at?
If they are the right struts, it's definitely an install error. D specs don't hit the hood when done properly. You need to thoroughly inspect your suspension to see why the passenger side is leaning. Like above, start taking stuff apart until you discover a mistake or problem.
Old Jul 26, 2012
GolNat's Avatar
Prelude Owner
The paper work might not match the actual strut. Look on the strut housing and find the model number on the strut, and match that to the number on there website. Whoever sent them might have grabbed the wrong box, or a different strut got put in the wrong box. I have D-Specs in the rear and am saving up to get the fronts, and in the research I did befor deciding to go with the D-Specs I did not read any mention of any issues with them fitting.
Old Jul 26, 2012
BlueEM2's Avatar
Whachya lookin at?
^ I also did some reading and nobody has this issue except you. They are probably the wrong struts.
Old Jul 27, 2012
tdawg50's Avatar
Freaking Awesome! Well, I'm working a ton this weekend but next week I will have time to tear into it. Actually, Sunday Might work. I'm gonnna take a picture of the wheel camber and out it up here in the next day or two and then Sunday I will take the struts out. I sorta feel like an idiot. I should've figured they were the wrong struts waaaaaay before now. Oh well, live and learn I guess. Hopefully I can fix things relatively soon. Thanks for all the help guys. I will keep you updated.
