HELP!! hit dip in civic and wont start now
Hello, I hit a dip in my civic the other day. My airbags deployed and oil pan cracked. I replaced my oil pan, BUT now it wont start. I believe I dont have a spark, any ideas? I hooked up my scanner and it just said, communicating with computer and nothing happend. NEED HELP, thank you very much for your time.
Re: HELP!! hit dip in civic and wont start now
easiest way to see if your getting spark is take a screw driver and take a spark plug wire... stick the screw driver in the spark plug wire and hold it close to metal and have somebody turn the car over.... if you dont get a spark then its probably in your distributer... if you get a orange or yellow spark then its in your distributer as well.. spark needs to be blue... the darker the color the hotter the spark.. the orange or yellow isnt hot enough... had a b20 do that to me and it sucked.... also check the the fuses to make sure none of them are blown
Jonnie.
Jan 13, 2019 11:21 AM
dragonsblood
Apr 27, 2015 12:28 PM
Linda0818
Apr 23, 2015 11:30 AM
